power cap question?
raptor333
Member - Posts: 46
Posted: July 07, 2004 at 9:16 AM / IP Logged
Hi, I have 3 power caps connected together by top mounting bars. Where should i put the postive and negative cables and the power cable to  my amp?
DYohn
Platinum - Posts: 10,741
Posted: July 07, 2004 at 10:43 AM / IP Logged
Positive cable from the battery to the positive side bus bar on the caps.  Positive cable to amp from the same positive bus bar.  Negative cable from the negative bus bar on the caps connected directly to ground.  Negative cable for the amp connected from amplifier ground directly to ground.  And don't forget your fuses.
raptor333
Member - Posts: 46
Posted: July 08, 2004 at 12:41 AM / IP Logged
thank you I just got eveything hooked up today and it sounds awesome.
Monday, May 4, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
