How to calculate air space in a f/g box?
extremecustoms2
Posted: July 10, 2004 at 6:37 PM / IP Logged
Im getting ready to build a fiberglass sub box but i need help calculating the air space i know how to on other sub boxes but now with the different shapes like a molded f/g box...any help would be nice...
xtreamcc
Silver - Posts: 467
Posted: July 10, 2004 at 7:49 PM / IP Logged
look at it from the side and measure out the full area and make a scaled down drawling on a piece of paper. Break it down into shapes that can be measured and get as much of the space as possible into the shapes. Then do the same thing from the front and from the top to get your LxWxH and the add all the areas together. Depending on how much space cannot be calculated in this method add a .1cuft or 6 depending on how much untill you feet that its close. Its not a 100% accurate way to measure the space but it can get you close. Theres otherways like filling it with sand and measuring it with a cylender formula but those methods are messy and sand isn't light in bulk so its not always practical.
"Shiny chrome when used in conjunction with bikini models is particularly effective in inducing brain deficit disorder"
02 Jeep Grand Cherokee
Monster System on its way.
pureRF
Silver - Posts: 619
Posted: July 10, 2004 at 11:52 PM / IP Logged
Use the sand. Also, try searching for this post cause its been asked a lot.
dream it, build it, fiberglass it
mob.dynam.grad
Copper - Posts: 73
Posted: July 11, 2004 at 1:22 AM / IP Logged
the easiest method that i have found is taking packing popcorn or packing foam.  You can usually buy big bags of it at office supply stores or any post office.  You can figure out how many cubic feet that you  need for the speaker and convert it from cubic feet to litres.  After that just take a juice jug or something with a litre measurement on it and start tapping that up and dumping the foam into the enclosure jug by jug until you have the required litres.  Remeber that 1 cubic foot of volume is equal to 28.32 litres.
Silverciv
Member - Posts: 23
Posted: July 14, 2004 at 12:47 AM / IP Logged
7.5 gallons = 1cu ft line the pbox with plastic or a large trash bag and water test it
the packing peanut method will get you within 5%+/- of the accurate amount
mob.dynam.grad
Copper - Posts: 73
Posted: July 14, 2004 at 12:25 PM / IP Logged
Why would the packing popcorn method make a 5% +/- difference??
Silverciv
Member - Posts: 23
Posted: July 14, 2004 at 12:36 PM / IP Logged
the way the packing peanuts settle
archemedes
Copper - Posts: 172
Posted: July 14, 2004 at 12:39 PM / IP Logged
there are air gaps in packing materials
mob.dynam.grad
Copper - Posts: 73
Posted: July 14, 2004 at 1:08 PM / IP Logged
but there are airgaps also in the box with the peanuts in the box.  So wat is the difference between airgaps in the litre measuring jug....compared to air gaps in the box?
Fender2martin
Member - Posts: 30
Posted: July 14, 2004 at 1:12 PM / IP Logged
I would have to agree..... if you take a cardboard box made to 1 cu-ft....  fill it with the peanuts... then that amount of peanuts will alwyas be 1 cu-ft no matter how they settle.... the air gaps you get in the final measurment are present in the first measurment...
Thursday, July 17, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
