2004 Ford Explorer sunroof
hrdottawa
Posted: July 14, 2004 at 8:17 PM / IP Logged
I am looking at purchasing a Valet 554R, I have no problems with the basic instalation. But I would like to know if there is any way to remotly close my sunroof, I tend to leave it open and I would like the option of closing it from inside the house if it starts to rains.
Thanks Brian.
spl-Hz
Copper - Posts: 94
Posted: July 15, 2004 at 11:15 PM / IP Logged
I have a 01 explorer sport trac with 4 way sunroof  2 way switch. I used a product  called twindow TS-1A.With this unit you can use ing. on close input,so when its turned off it see ground and closes automaticly. But the unit is made for pos. switchs so I had to change it to neg. with relays. I also used the up input to vent the sunroof. It works grate. This unit has a memory so it knows  were the roof last stopped. I could have any output on my alarm to closr it but I still kept forgeting to always close it. So ing.off ,automatic close I like best.  good luck.
jaurora
Silver - Posts: 429
Posted: July 16, 2004 at 6:35 AM / IP Logged
Be sure you use a module made for a sunroof and not a power window. There are differences between the two so be carefull on selecting the proper one.
MECP certified (If it really means anything)
Jeremy
spl-Hz
Copper - Posts: 94
Posted: July 16, 2004 at 8:50 AM / IP Logged
it is
jaurora
Silver - Posts: 429
Posted: July 16, 2004 at 8:58 AM / IP Logged
I just wanted it to be a FYI because I have seen plenty of expensive mistakes before. If it helps 1 person who reads this post it is worth it!
Jeremy
hrdottawa
Posted: July 17, 2004 at 12:04 PM / IP Logged
spl-Hz,
The power Sunroof switch sounds the same, can you tell me where you got your twindow TS-1A module from.
I have tried doing a quick search in Google with no luck.
Thanks BrianT, Ottawa. Canada.
spl-Hz
Copper - Posts: 94
Posted: July 17, 2004 at 5:39 PM / IP Logged
  I got it from a wholesale outfit Calif. Micro Alarm,if your not a reseller call some of the local shops. The manufactor is Micro Sceinces aiso  in Calif.  Model  # TS-1A
Tuesday, February 17, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
