2001 focus zx3 alarm install
tblanset
Posted: September 12, 2002 at 7:32 AM / IP Logged
Is the wiring diagram same for 01's as 00's? I assume it is but if anyone knows for sure or knows where I can get the wiring diagram pls let me know.
tman
the12volt
Administrator - Posts: 3,957
Posted: September 12, 2002 at 10:54 AM / IP Logged
THEY ARE DIFFERENT. HERE'S WHAT I HAVE FOR A 2001 FOCUS:
FACTORY KEYLESS SYSTEM   RH A-PILLAR    2/16 PIN CONNECTORS
FACTORY SECURITY SYSTEM   RH A-PILLAR    2/16 PIN CONNECTORS
P.C.M. LOCATION   RH A-PILLAR    104 PIN CONNECTOR
BCM LOCATION     G.E.M.  CENTRAL JUNCTION BOX   BEHIND L/S OF DASH THERE IS NO GEM JUST CJB WITH TIMER
DOOR TRIGGER  BK/BU   13 OF 15 AT CJB   NEG.
LF LATCH SWITCH  BK/OR   13 OF 15 AT CJB   NEG.   BK/YE 14 OF 15 WITHOUT ANTITHEFT
RF LATCH SWITCH  BK/BU   13 OF 15 AT CJB   NEG.
LR LATCH SWITCH  BK/BU   13 OF 15 AT CJB   NEG.
RR LATCH SWITCH  BK/BU   13 OF 15 AT CJB   NEG.
DOME LIGHT  BK/BU   5 OF 11 AT CJB   NEG.
TRUNK TRIGGER  BK/OR   1 OF BU 16 ANTI/TH   NEG.   WITH ANTITHEFT ONLY
HOOD TRIGGER  BK/YE   3 OF BU 16 ANTI/TH   NEG.   WITH ANTITHEFT ONLY
+12 V DC START OR CRANK  GY/BK   IGN. SW. HARNESS   POS.
+12 V DC ACCESSORY  YE   IGN. SW. HARNESS   POS.
+12 V DC IGN.1  GN/YE   IGN. SW. HARNESS   POS.
+12 V DC IGN.3     NOTE: KEY-IN=RD/BK (POS.) IGN. SW. HARNESS
+12 V DC BATTERY 1  RD   IGN. SW. HARNESS   POS.
+12 V DC DOME LIGHT FUSE  OR/BU   2 OF 11 AT CJB   POS.
TRUNK RELEASE  BK/YE   3 OF 16 ANTITHEFT   NEG.  " ALSO WH/GN, 2 OF 16 ANTITHEFT (POS.) "
HIGH CURRENT PARKING LTS  OR/GY   LIGHT SWITCH   POS.   ALSO 6 OF 10 AT CJB
LF BULB  OR/YE   2 OF 10 AT CJB   POS.   TWO WIRES PER PIN (OR/YE AND OG/WH)
RF BULB  OR/BU   8 OF 10 AT CJB   POS.   TWO WIRES PER PIN (OR/BU AND OR)
LR BULB  OR/WH   2 OF 10 AT CJB   POS.   TWO WIRES PER PIN (OR/YE AND OG/WH)
RR BULB  OR   8 OF 10 AT CJB   POS.   TWO WIRES PER PIN (OR/BU AND OR)
DOOR LOCK CIRCUIT TYPE  3-WIRE NEG.
DOOR LOCK  BK/RD   12 OF 16 ANTITHEFT   NEG.   GREEN CONNECTOR
DOOR UNLOCK  BK/YE   15 OF 16 ANTITHEFT   NEG.   GREEN CONNECTOR
FACTORY SECURITY ARM  BK/BU   9 OF 16 ANTITHEFT   NEG.   GREEN CONNECTOR
FACTORY SECURITY DISARM  BK/WH   15 OF 16 ANTITHEFT   NEG.   GREEN CONNECTOR
DRIVER'S DOOR LOCK MOTOR  YE/BK   8 OF 16 ANTITHEFT   POS.   GREEN CONNECTOR
DRIVER'S DOOR UNLOCK MTR  WH/BK   7 OF 16 ANTITHEFT   POS.   GREEN CONNECTOR
PASS DOOR LOCK MOTOR  YE/BK   8 OF 16 ANTITHEFT   POS.   GREEN CONNECTOR
PASS DOOR UNLOCK MOTOR  WH/BK   6 OF 16 ANTITHEFT   POS.   GREEN CONNECTOR
2 STEP UNLK W/ FACT KEYLESS?  YES
TACH REFERENCE BK/OR 26 OF PCM NEG.
CRNKSHFT POSITION SENSOR  BN/RD   22 OF PCM   NEG.
CAMSHAFT POSITION SENSOR  VT/WH   85 OF PCM   NEG.
FUEL INJECTOR  BK/WH   70 OF PCM   NEG.
BRAKE SWITCH  GN/RD   BRAKE SWITCH   POS.
NEUTRAL SAFETY   USE START (BY/BK)   POS.
REVERSE LIGHTS  GN/YE   16 OF 40 L/ A-PILLAR   POS.
HORN SWITCH  BK/BU   STEERING COLUMN   NEG.   ALSO BK/GN 8 OF BU 16 AT ANTITHEFT
HAZARD LIGHT CIRCUIT TYPE  4 WAY   4 OUTPUT   POS.
LEFT FRONT HAZARD  BU/WH   MULTIFUNCTION   POS.
RIGHT FRONT HAZARD  BU/RD   MULTIFUNCTION   POS.
LEFT REAR HAZARD  BU   MULTIFUNCTION   POS.
RIGHT REAR HAZARD  BU/YE   MULTIFUNCTION   POS.
HEADLIGHTS  GN/RD   MULTIFUNCTION   POS.
HEADLIGHT SWITCH   L/S OF DASH
HIGH BEAM SENSE  GN/YE   MULTIFUNCTION   POS.
PWR WINDOW CIRCUIT TYPE  REVERSAL   REST AT GROUND   POS.
DRIVER'S WINDOW UP  YE   DRIVER'S SWITCH   POS.
DRIVER'S WINDOW DOWN  GN/BK   DRIVER'S SWITCH   POS.
R.F. WINDOW UP  YE/VT   DRIVER'S SWITCH   POS.
R.F. WINDOW DOWN  WH/VT   DRIVER'S SWITCH   POS.
L.R. WINDOW UP  YE/BU   DRIVER'S SWITCH   POS.
L.R. WINDOW DOWN  WH/BU   DRIVER'S SWITCH   POS.
RR WINDOW UP  YE   DRIVER'S SWITCH   POS.
RR WINDOW DOWN  WH   DRIVER'S SWITCH   POS.
VSS SPEED SENSOR  WH/BU   58 OF PCM  " 8,000 "  ZETEC (4-V) ENGINE WITH M/T=24000
IMMOBILIZER PRESENT?  YES
TYPE OF IMMOBILIZER?  TRANSPOND
Wednesday, December 31, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
