2000 Honda Odyssey door trigger
matd1969
Posted: July 15, 2004 at 9:21 AM / IP Logged
Hi
I got the wiring color code and location guide for installing an alarm on my Honda Odyssey Mininvan here at the 12volt but i can't find the location for the door trigger for all doors. The guide says that i should take it at the dome light switch but it is too complicated to remove the dashboard to get to the dome light switch. Another source says that this is a WHITE/ black wire in a blue connector next to the steering wheel but i just can't find it.
If any member knows the color code and exactly where it is i would appreciate it very much if you reply to this message, thanks.
Angel T.
profuse007
Gold - Posts: 2,015
Posted: July 15, 2004 at 8:28 PM / IP Logged
DOME LIGHT BLACK/ WHITE ( - ) ALARM PLUG RIGHT OF STEER COLUMN
Houston,TX
matd1969
Posted: July 19, 2004 at 4:15 PM / IP Logged
I am sorry but i can't find this black with white wire right next to the steering shaft. What color and how many pins is this connector? I am kind of new doing the alarm install on my odyssey.
Thanks.
Angel T.
Moderator - Posts: 12,488
Posted: July 20, 2004 at 8:58 AM / IP Logged
Look for the multiplex control unit on the passengerside kickpanel. It's Pin A21 ( BLACK/ WHITE)  which is the interior light switch wire.
Monday, December 22, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
