Posted: July 15, 2004 at 11:50 PM / IP Logged
Posted: July 16, 2004 at 12:11 AM / IP Logged
Posted: July 16, 2004 at 4:16 PM / IP Logged
Posted: July 16, 2004 at 4:53 PM / IP Logged
Posted: July 17, 2004 at 2:27 AM / IP Logged
Posted: July 17, 2004 at 7:06 AM / IP Logged
Monday, March 30, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
) do not worry about the display, it does nothing to help or hinder the function of a cap... hook it up and forget about it.
a cap CANNOT discharge at a voltage that is higher than it is supplied with, so, because your car is 14.4 (nominal, engine running) the cap cannot supply more than 14.4 volts for the amplifier consumption - if a cap could supply more voltage than it is supplied WITH, then it would be an amplifier. a cap is a voltage device, meaning it will provide as much current it can, for as long as it can... as long as there is charge in it. it does this by dumping as many electrons as it has for as long as it can into the load. if the load is small, the dump can last a significant amount of time (low current, similar to a SMALL battery) if the load is big, the time frame will be shorter (high current) but always 14.4 volts. the more current dumped, the shorter the time it can dump it. the amount of current it can supply is determined by the ESR (equivalent series resistance) of the cap - lower ESR = more current - this is why you want the lowest ESR you can locate. Granted, the voltage WILL begin to drop, but not until VERY LATE (relatively speaking) in the discharge cycle.
