boosting a signal?
Alpine Guy
Platinum - Posts: 2,478
Posted: July 17, 2004 at 10:52 PM / IP Logged
How would i wire up a bosch relay to take a  (+)signal, and boost it from the battery to spit out a amplified (+) signal.
auex
Platinum - Posts: 5,041
Posted: July 17, 2004 at 11:59 PM / IP Logged
Well, what exactly are you trying to do? If you are trying to turn a low level input to a high level output(not neccessarily amplified) it would be: 85 + activation input, 86 ground, 30 Constant +12V, and 87 + output.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Alpine Guy
Posted: July 18, 2004 at 10:08 AM / IP Logged
im upgradeing my headlight wireing.  I purchased a new set of 9004 plugs with 12 awg wires so all i need to do is take the original power signal, run it through a relay then feed it back out through the 12 awg wire into my bulbs.
Alpine Guy
Posted: July 18, 2004 at 10:09 AM / IP Logged
im guessing it would be the same relay set up as if i were to be adding a 2nd ignition relay to a car starter than only has 1 output.  am i right?
Teamrf
Gold - Posts: 1,031
Posted: July 19, 2004 at 8:01 AM / IP Logged
So you just want to boost your headlight wire?
~The Rookie~
Rookie of the year that is...
Don't let the smoke out of your equiptment..it doesn't go back in.
Nstaller36609
Member - Posts: 24
Posted: July 19, 2004 at 6:29 PM / IP Logged
Relays dont amplify they use a small amount of voltage or current to control a larger voltage or current.All they are is an electric switch.
Alpine Guy
Posted: July 19, 2004 at 10:47 PM / IP Logged
whell, , i want to take the wimpy lil signal from the factory wires, , and isolate them and power them directly from the battery which is a more realistic to power high power headlights, , get what im saying now??
Nstaller36609
Member - Posts: 24
Posted: July 20, 2004 at 8:42 AM / IP Logged
hook factory headlight wire to 85 ,ground to 86, new lights to 30 and batt to 87
Alpine Guy
Posted: July 20, 2004 at 9:16 PM / IP Logged
thanks!     Also, , just wondering about the ground wire on the head light, , should i permanently ground it, , or should i use a relay set up also?  triggered from the factory ground wire?
Nstaller36609
Member - Posts: 24
Posted: July 21, 2004 at 4:23 PM / IP Logged
If the ground wire stays grounded when the high beams are on just ground the wire on the new harness.If it doesnt (ex. low beams go off when high beams are turned on)use the same relay setup  but be sure to change the  polarity on 87(change to -)and 86(change to +)
Sunday, February 15, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
