aftermarket door lokcs toy-corolla
SSteve
Member - Posts: 20
Posted: July 22, 2004 at 4:07 PM / IP Logged
THANK YOU,
I WANT TO INSTALL DOOR LOCK ACTUATORS IN A 2004 TOYOTA COROLLA BUT I CAN'T DO IT BECAUSE THERE IS NO RHODS, THEY USED CABLES (LIKE THE TRUNK OPENER KIND) AND IT SEEMS LIKE THERE IS NOT WAY TO DO THIS.
PLEASE COULD ANYBODY GIVE ME A HINT
Steve
desh187
Copper - Posts: 310
Posted: July 22, 2004 at 9:05 PM / IP Logged
It is not easy but you can if done very precisely.you would have to drill a hole on the door opening handle assembly to pass the actuator rod thru and then you have a little room where the rod attaches to door lock/unlock assy.
arteaga777
Posted: July 22, 2004 at 9:43 PM / IP Logged
I have done it before all you have to do it cut a piece of the door lock cable insulation and attach the actuator rod to the inner thin cable.
Drey
Member - Posts: 35
Posted: July 23, 2004 at 10:49 AM / IP Logged
sounds like a pain
Thursday, February 19, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
