Matrix remote won’t work anymore
milenko
Member - Posts: 14
Posted: July 23, 2004 at 1:53 PM / IP Logged
I have a clifford matrix 2.5x and last night I got the remote wet.
I took it all apart, dried it with a hairdryer, thing is completely dry. I put it all back together, pressed the lock button, and I get the beeps as if I was out of range.
I figured I had to re-program the remote, so I hooked up the valet switch and tried as the manual said...press once, press again and hold, then press a transmitter button to auto program the remote. I did that with no luck.
Am I doing something wrong? I believe the remote will work since it beeps fine, vibrates fine, and the display is fine. Maybe I'm wrong.
sroth140
Silver - Posts: 513
Posted: July 23, 2004 at 3:22 PM / IP Logged
maybe  you toasted the sending part.  usually when something gets wet... its not fine.  you might need a replacement  $50-$100.
MECP certified installer
milenko
Member - Posts: 14
Posted: July 23, 2004 at 4:28 PM / IP Logged
eh..I went to the place, they replaced it for free. Pretty cool.
Friday, April 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
