Single or Dual voice coil?
jonbth
Member - Posts: 42
Posted: July 24, 2004 at 3:36 PM / IP Logged
I have a Nissan pick up with a pair of component speakers. I want to buy a 200w x 4 amplifier and add a 10" sub woofer. What would be better? Buy a single voice coil woofer and bridge the amp or a dual voice coil and run 2 channels into it?
kgerry
Platinum - Posts: 3,455
Posted: July 24, 2004 at 3:50 PM / IP Logged
why not just buy a 2 channel stereo/bridgable amp and a good S or DVC sub?    a 4 channel amp cant be bridged properly to a single load.....
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
shaman
Copper - Posts: 70
Posted: July 24, 2004 at 3:57 PM / IP Logged
Yor optionas would be,
1. SVC brige 2 channels for 400w on the sub and have two channels free- mabey for components?
2. DVC bridge two channels together, take the two briged outputs and drive both channels of the sub (why?).
3. Run the DVC sub with two channels and leave two for components, etc.
What are you trying to do exactly?  What equipment are you looking at?
shaman
Copper - Posts: 70
Posted: July 24, 2004 at 4:00 PM / IP Logged
If you want to run everything from one amp I would only consider a DVC if your gonnal upgrade or change vehicles because it leaves alot more configuration options, but for you a SVC would work just fine.
stevdart
Platinum - Posts: 5,816
Posted: July 24, 2004 at 4:05 PM / IP Logged
I think, if I understand your question right, that you believe that a woofer with dual voice coils would need two hookups to an amp.  Not the case, as DVC woofers are available to supply us with an endless array of configuration possibilities, depending on what the coils are and how many we use.  In your case, you want to use one sub.  The total of the coils impedence have to match your amplifier rating.  If you want to use one amp to power the front components and a sub, a four channel amp will work.  The sub should be either a single coil 4 ohm, or a dual coil 2 ohm.  See this wizard for the different wiring configurations using DVC subs.  The RMS rating of the sub has nothing to do with the number of coils, and should closely match the amplifier power at its bridged rating.  So wire the components to channels one and two, and bridge the sub to channels three and four.
Otherwise, if I read your question another way, you want to know if wiring two coils to separate channels is better than bridging?  No.  Wire the coils together on the sub, then bridge to the amp.
I am presuming you meant a 50 X 4 amp, total of 200 watts @ 4 ohm.  If you are talking 800 watts at 4 ohm, though, like your post indicates...there are some other better solutions.  In that case, post up what you are looking at and what you want to achieve.
jonbth
Member - Posts: 42
Posted: July 25, 2004 at 1:23 AM / IP Logged
I meant 50W X 4. Thank you Stevdart for the info.
shaman
Copper - Posts: 70
Posted: July 25, 2004 at 11:28 AM / IP Logged
what is the resistance of the dvc sub, and what can your amp handle?  2Ohm, 4Ohm, etc.
