Stabilizing Power
Ravendarat
Platinum - Posts: 2,806
Posted: July 25, 2004 at 9:57 AM / IP Logged
Let me bounce this off all you experienced guys out there. My boss was telling me that after I put in my HO altenator I should retain the battery under my hood then connect a pair of caps UNDER THE HOOD as well, then from the caps go to a second battery inside the vehicle compartment. His reasoning is that the caps would work similar to a line driver and help stabilize the voltage going to the back of the vehicle, which in theroy should help eliminate those peaks and valleys in the power line when the amps are drawing more power then less power. It seemed like an interesting concept to me but something, I cant place my finger on it, but something tells me this wont work. Any thoughts on this. And by the way I understand that the second battery will just give me more reserve but I do do competions so the extra reserve is welcome as well as I do use my truck for promotional purposes outside my store so its gonna help out there. The question is more about the act of connecting the battery then the caps and then another battery in that order. Also I do live in Canada so I have to deal with some pretty extreme climates so will the caps even stand up to the elemets, I have never heard of some one using them under the hood so I never even thought to check if you could.
DYohn
Platinum - Posts: 10,741
Posted: July 25, 2004 at 10:40 AM / IP Logged
A couple of points.  1) Electricity doesn't care if it's at one ond of the wire or the other, as long as it's in the wire.  2) Putting caps in the engine compartment exposes them to a grat deal more heat than mounting them elsewhere, and capacitors HATE heat.  Sure to shorten their life and make them fail sooner.  3) Caps cannot "work similar to a line driver" unless this is simply a flowery metaphor and not a literal analogy.  4) Eliminating thos "peaks and valleys in the power line" is simply double-talk.  The sole purpose of a power cap is to enhance system stability for the AMP.  The power line, alternator, battery, etc. don't care about "peaks and valleys," only YOU care if it affects the amplifier's output.  Mounting caps far away from the battery will increase the time delay (the RC time constant) for their discharge/charge cycle, and you may notice less of an effect on amplifier power output.  They simply may no longer react quickly enough to help the amp.
Those are a few ideas off the top of my groggy head as I haven't had my coffee yet this morning...
haemphyst
Platinum - Posts: 5,059
Posted: July 25, 2004 at 10:46 AM / IP Logged
Adding caps under the hood will do nothing, besides burn up your cash. As long as your power cable to the trunk is of acceptable gauge, your voltage drop will be within acceptable tolerances. If your cable is too small, having a cap will do nothing for the unacceptably high voltage drop. It will still drop the same amount by the time it gets to the trunk. In fact, it may be ever so slightly worse, owing to the fact that you have even more connections in your power cable. The purpose for the cap is twofold.
1) To provide CURRENT when the amplifier demands it, thus minimizing voltage drop, BUT the cap must be installed within 18 inches of the amplifier. Voltage drop will change, based on the current and distance. Example: If you have a 4 gauge cable, and your acceptable voltage drop is, let's say .5 volt, and you are only using it to carry 10 amps of current, you can go 10 TIMES FURTHER with that same #4 than if you were using a #4 for 100 amps of current. What this means is, if you put the caps under the hood, and if your amplifiers are pulling 100 amps, and you are using a #4 wire to your trunk, you will have EXACTLY the same voltage drop at the trunk as you would WITHOUT the caps under the hood. Now, if the cap is in the trunk, and your amplifier requires a 100 amp gulp of current, the voltage drop WILL still be present, but with the cap NEXT TO the amplifier, the voltage drop will be filled in by the LOW IMPEDANCE OUTPUT of the capacitor, thereby filling in the voltage sag generated by the voltage drop over the power cable.
and 2) filtering, which is a single word describing the above process, so really, a cap only does one thing... Stabilizing Power -- posted image.
The second battery is, indeed, the better way to go. If you go this way, you DO NOT NEED ANY ISOLATION! You have a HO alternator, you will have PLENTY of current to charge both batteries, and keep them charged. For those that believe an isolator is necessary, I will tell them right now that is wrong. A relay type of isolator will always favor the lowest charge... which one is that? Most likey the system battery in the trunk, and thus, this battery will demand more charge time than the battery in the front. This will mean the front battery is almost always undercharged, mandating replacement sooner. The solid state type (diode isolation) will allow too much voltage drop, and unless you have an EXTERNAL voltage regulator for the alternator (and almost all of them are internal today) and/or a voltage monitor/control regulator to maintain proper voltage to BOTH batteries, they will both be in a largely undercharged state, again mandating replacement sooner than necessary. It is IMPERATIVE, therefor, that your batteries be the same type, manufacturer, CCA, reserve time, and age. If they are significantly different from one another, you WILL get parasitic current drains, either one way or the other. (front to rear, or rear to front) This will cause one battery to die faster than the other. If you START with identical batteries, you will, from that day on, be able to (and, unfortunately, be required to) simply buy two batteries at a time, and replace them simultaneously... I agree, additional expense, but what are you going to do? - ah, the necessary evils of our craft and love, hmmm?
Yes, a second battery will give more reserve time, but it will also provide better current and voltage stability than even a cap could. A cap is ALWAYS optional, but with a second battery, it becomes even moreso, and more than likely, completely unnecessary. With a second battery, your voltage drop will halve itself, because the front battery will be supplying half of the current demanded, instead of all of it, and the back battery will be providing half. With half of the demand being supplied by each battery, the charge on both batteries will drop equally, and the alternator will be able to maintain the charge to both correctly.
Ravendarat
Posted: July 25, 2004 at 7:02 PM / IP Logged
See, thats why I posted this. My boss spent like an hour explaing this to me and it didnt seem to make much sense to  me either but Its impossible to ever tell him he's wrong so I dont try anymore. Thanks for the clarification.
Friday, March 13, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
