Amp has little sound
*Kicker
Posted: July 25, 2004 at 5:58 PM / IP Logged
Okay, so i found the pink wire, you guys told me about...and now my amp is working fine, but with one little problem.....I hardly have any sound coming out of my sub........I have an 850 Ultimate (2x425Watts) powering a Kicker sqaure 10" Sub...I have no boom to it........Is It a problem with my ground or is there something else I missed???
archemedes
Copper - Posts: 172
Posted: July 25, 2004 at 6:07 PM / IP Logged
have you adjusted the gains?
*Kicker
Posted: July 25, 2004 at 6:12 PM / IP Logged
yes i have....I still have my factory deck I am using, and used a high-low frequency relay, that run off my rear speakers and connect to my amp by RCA outputs
forbidden
Platinum - Posts: 5,353
Posted: July 26, 2004 at 6:10 PM / IP Logged
Did you wire the sub incorrectly. This is a dvc sub correct? How is it wired?
stereofreak
Member - Posts: 37
Posted: July 27, 2004 at 9:44 PM / IP Logged
sounds like the coils are wired against each other.reverse one of the coils and see if it moves.
if i can't make it sound good,then it is just a piece of crap anyway
Focusdsound
Posted: July 27, 2004 at 10:32 PM / IP Logged
I just can' t help myself....Why don't you put it in a little car.....LOL
Focusdsound
Posted: July 27, 2004 at 10:34 PM / IP Logged
Ok seriously....when you wired the Line Out Convertor did you make sure to wire the speaker wires pos and neg correctly otherwise you would of wired your inputs out of phase.
Wednesday, July 16, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
