2003 Jaguar S type R, stereo, engine noise
DYohn
Platinum - Posts: 10,741
Posted: August 04, 2004 at 2:56 PM / IP Logged
AH no, you have the Nav system, I do not.  That is a different animal that was developed by Denso and Pioneer.  I cannot help you with this head.  Sorry.  The factory subs run off two 32 watt amplifiers located in the sub enclosure under the rear package tray.  The door speakers run off their own amplifier.
styper
Member - Posts: 25
Posted: August 04, 2004 at 4:27 PM / IP Logged
dyohn,
I believe you have this car confused with the 2000-2002 Jags. All the speakers in this car are ran off of one factory amp, located in the trunk.....
S type R.
styper
Member - Posts: 25
Posted: August 05, 2004 at 4:03 AM / IP Logged
I had this posted in the wrong forum..
To all that helped with my previous post "jaguar engine noise" thank, however the saga dosn't quite end.
Car = 03 Jag S type R.
I am using LOC off my stock amp, the battery, LOC,stock amp and aftermarket amp are located in the trunk.
I have found there is still engine noise, even after I short the amp with the muting plugs. I re-grounding my amp didn't help, I changed RCA cables didn't help.
I am fairly sure now the noise is coming in from the amp.
The amp is a JBL GTQ 400.
However when I used a Walkman connected to the amp instead of my stock head unit, the engine noise disappeared.
Any suggestions.
S type R.
raydawg357
Silver - Posts: 769
Posted: August 05, 2004 at 8:07 AM / IP Logged
How close are your RCA's ran to your power wire?  Your amp could have a bad noise filter also.
Do it right the first time
Francious70
Silver - Posts: 629
Posted: August 05, 2004 at 9:25 AM / IP Logged
That was the same problem I was having with my Pyramid Crystal. After shorting the amp, noise continued, replaced and re-ran RCA', still noise. Replaced the amp, noise gone. So yea, replace the amp.
Paul
styper
Member - Posts: 25
Posted: August 05, 2004 at 1:30 PM / IP Logged
The RCA are not close to the Power at all. Keep in mind the battery in this car is in the trunk, so the power is on one side and the RCA are on the oppisite side. I need to get another amp to try. I am going to try to replace the amp and see what happens.
S type R.
kgerry
Platinum - Posts: 3,455
Posted: August 05, 2004 at 1:40 PM / IP Logged
when using the walkman was it getting power and ground from the vehicle or running off batteries?
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
styper
Member - Posts: 25
Posted: August 05, 2004 at 6:21 PM / IP Logged
the walkman was running off batteries.
S type R.
Saturday, May 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
