2004 scion xa alarm
creole_7
Posted: August 07, 2004 at 2:13 AM / IP Logged
anyone have any idea on the wiring for the new scion xa
draasch
Gold - Posts: 2,172
Posted: August 07, 2004 at 7:39 AM / IP Logged
Make:   Scion
Model: xA
Year:    2004
Alarm
Constant 12 volts WHITE/ BLUE IGNITION SWITCH HARNESS
Ignition 12 volts BLACK / YELLOW IGNITION SWITCH HARNESS
Starter BLACK IGNITION SWITCH HARNESS
Dome Light RED (-) AT ILLUMINATION RELAY L OF FUSE BOX*
Trunk Pin Switch RED (-) SAME AS DOME LIGHT
Parking Lamp GREEN (+) AT LIGHT SWITCH
Power Lock BROWN / WHITE DRIVERS KICK #201
Power Unlock GREEN / WHITE DRIVERS KICK
* Fuse Box Left Of Steering Column #201 - See Negative Pulse Door Lock
Accessories
Window Up D\ RED P\ BLU/WHT D\ RED / YEL P\ RED / BLK @ DR DOOR #211
Window Down F/ GRN F/ BLU/YEL R/ GRN/YEL R/ GRN/BLK SWITCH
Ign Key Warn YELLOW (-) AT KEY CYLINDER SWITCH
Trunk Release N/A
OEM Horn WHITE/ RED (-) AT STEERING COLUMN HARNESS*
Headlights RED / YELLOW (-) AT HEADLIGHT SWITCH
OEM Alarm Arm NO OEM ALARM
OEM Alarm Disarm
#211- See Reversal Rest At Ground Power Window Circuit Diagram. * Also Beind Fuse Box In A Blue 13 Pin Connector
Remote Start
Tach Signal GREEN/ RED AT IGNITION COIL #1 UNDER HOOD *
Ignition #2 BLACK/ RED IGNITION SWITCH HARNESS
Ignition #3 N/A
Accessory WHITE/ BLUE IGNITION SWITCH HARNESS
Neutral Safety RED / WHITE (+) LEFT SIDE OF BLOWER
Brake Light GREEN / WHITE (+) AT SWITCH ABOVE BRAKE PEDAL
Reverse Light RED / WHITE TO LEFT OF BATTERY
Rear Window Defrost RED / BLACK (+) AT DEFROST SWITCH **
* Also At ECM Located Behind Glove Box. ** Needs 12 Volts To Opperate, A Pulse Will Not Turn Unit On.
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
Wednesday, March 11, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
