I want the horn to sound when I arm
twisty1er
Member - Posts: 21
Posted: August 13, 2004 at 4:43 PM / IP Logged
I had installed a Performance Teknique ICBM 7071 but It doesn't have a horn output can I make the horn sound when the alarm goes off and when I arm it with a relay??????
And can you tell me how to wire the relay thnx to anyone that can help
badnad
Member - Posts: 9
Posted: August 19, 2004 at 7:25 AM / IP Logged
first of all, do you have a siren output or light output in that alarm system?. does the lights flash once to arm or to disarm, only then i can provide you the information onto how to wire it with a relay.
I'll be back, so nobody go no where
raydawg357
Silver - Posts: 769
Posted: August 19, 2004 at 7:27 AM / IP Logged
There's a diagram posted on this site under the relay section for horn honk options
Do it right the first time
Frys24
Posted: August 19, 2004 at 2:42 PM / IP Logged
on most alarm harneses its the BROWN / white wire. most are -neg. and will need a relay.
connect BROWN / white  to terminal 85, connect relay terminals 86 & 87 to +12v constant power. connect terminal 30 to your horn wire.
if your horn wire is -neg then just use your BROWN / white wire. use a probe to find out
or you can use directed web site for a print out of your wiring and locations of the wiring to find out.
Fry's Electronics store #24 Concord, Ca.
auex
Platinum - Posts: 5,041
Posted: August 19, 2004 at 4:37 PM / IP Logged
This is a highly inaccurate statement. There are many alarms that don't offer offer a horn honk output.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
badnad
Member - Posts: 9
Posted: August 22, 2004 at 1:37 AM / IP Logged
you can use the light output, the siren output and the central locking wires (negative switching output using diodes but with all these, you will have to use a relay to drive the hight current to the horn honk.
hope this helps
