Any cautions about this setup?
JhnBrackett
Member - Posts: 19
Posted: August 16, 2004 at 9:13 AM / IP Logged
I don't have power anything in my 4 door car.  But am hoping to go to keyless entry and add an alarm.  I don't know if it'd be better to do just the front 2 doors, or wire the driver's side and the other 3 seperately (rear and passenger all on same button).  I won't add remote start cause its a manual.  Here's what I plan on buying.
Alarm w/ keyless entry option.  2 remotes.  Aux. trunk output, and 2 sep. lock/unlock buttons on remote.
2 or 4 2 wire actuators
What am I missing?  Are any extra relays needed?  I'll unlock the doors inside using the old mechanical attachment instead of a button. If I wanted to add door poppers I'd need to just have 2 extra channels on the remote and 2 solenoids correct?  Thanks a ton for the help.
raydawg357
Silver - Posts: 769
Posted: August 16, 2004 at 10:00 AM / IP Logged
I would add actuators to only the two front doors unless you always roll 4 deep.  Depending on the type of alarm you choose, you may need relays.  DEI alarms come with a relay pack.  If you don't have a push button trunk release, you will also need a trunk pop kit and depending on the alarms polarity on the options you may need a relay for this also.    The door lock actuators will work off of the lock and unlock buttons on your remote you won't need extra channels for this feature.
Do it right the first time
JhnBrackett
Member - Posts: 19
Posted: August 16, 2004 at 2:31 PM / IP Logged
I will need extra channels for a door popper kit, cause they are seperate devices from the actuators.
auex
Platinum - Posts: 5,041
Posted: August 16, 2004 at 3:12 PM / IP Logged
If you shave your door handles then you disconnect the locks from the actuator as to not get locked out completely.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
JhnBrackett
Member - Posts: 19
Posted: August 16, 2004 at 7:01 PM / IP Logged
Good point, but not plannin on doin shaved door handles yet, the door popper (passenger side) will be just for fun.  So I'll just have to make sure I do unlock, then pop
Thursday, December 25, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
