555F installation with Viper 555ESP
Blk02Xtreme
Posted: August 17, 2004 at 5:18 AM / IP Logged
Hello, I'm currently installing a 550ESP Remote Start Alarm into a 1997 Expedition. This is the first install I've had to use the 555F with and I'm a little confused on one part of the hookup. Basically I'm unsure if the 'Blue (-) Activation Input' requires a pulsed or constant signal from the brain. I have decided to use one of the following:
Harness2/Pin2 - (-) Factory Disarm Output - Pulse Type (Sends negative pulse when remote start is activated)
Harness3/Pin1 - (-) 200mA Status/Factory Re-Arm Output - Constant Type (Sends negative constant as soon as remote start process begins)
I don't see why the 555F unit would need anything more than pulse on activation, as the key is only checked on start-up to my knowledge. I don't have anything hooked up to either at present, so both are availble.
Also, is it absolutly neccesary to use a relay on this circuit? I can't imagine the 555F draws that much current.
Any assistance in this matter is greatly appreciated.
 Regards,
    Matt
Blk02Xtreme
Posted: August 17, 2004 at 5:20 AM / IP Logged
Typo in the title. As stated in the actual post, the model of the alarm is a Viper 550ESP; not a non-existant 555ESP.
Thanks again,
   Matt
tbirdman74
Copper - Posts: 164
Posted: August 17, 2004 at 8:51 AM / IP Logged
I believe that it needs to be activated the entire time that the remote start is engaged.  most of the GM's only check for the transponder at first, but I think Ford looks for it all the time.  I tapped the one I did into an Ign 2 (-) output with a relay so that when the alarm powered the Ign 2 circuit, it also powered the 555F.  Good luck.
If it don't fit, Force it.
If it breaks, You needed a new one anyway!
auex
Platinum - Posts: 5,041
Posted: August 17, 2004 at 9:36 AM / IP Logged
Use the wire labeled "status output". It should be blue or blue/black.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Blk02Xtreme
Posted: August 17, 2004 at 11:16 PM / IP Logged
Excellent, have a slight delay with this because the owner only has 1 key; so waiting for the locksmith to program up another one. But got the module all set. Most likely he will be purchasing the Ford interface kit, as I advised him it's much more reliable than this 555F pellet junk.
Thanks again for the responses!
Monday, May 4, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
