24-12V with isolated outputs
ghj20
Member - Posts: 7
Posted: August 17, 2004 at 7:51 PM / IP Logged
I am hoping to use the Alfatronix 24-12V DC-DC step down converter to power a HU in a 24V Jeep. Out put of the converter is said to be isolated(apparently  useful for petrochemical vehicles) However my problem is that if i use the positve and negative outputs of the converter for power and ground respectively, do i have to isolate the HU cage from the vehicle chasis? or is it ok the HU to touch the chasis. Any ideas? cheers
haemphyst
Platinum - Posts: 5,059
Posted: August 18, 2004 at 12:57 AM / IP Logged
If it is an isolated version, it must be just that - ISOLATED. If it is a common ground (earth) then the three chassis can all be electrically connected. Read you manual to determine which you have.
Sunday, May 10, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
