Alarm diagrams for 2002 Honda Passport
bendough
Posted: September 18, 2002 at 6:42 PM / IP Logged
Is the wiring the same as the 2000 model
bendough
Platinum - Posts: 12,488
Posted: September 18, 2002 at 7:26 PM / IP Logged
This is for the 2001 Passport:
|              12V|white, WHITE/ black  |+  |ignition harness            |
|          STARTER|BLACK/ white         |+  |ignition harness            |
|         IGNITION|BLACK / YELLOW        |+  |ignition harness            |
|  SECOND IGNITION|BLACK/ red           |+  |ignition harness            |
|        ACCESSORY|blue                |+  |ignition harness            |
|       POWER LOCK|lt. GREEN/ red       |-  |drivers kick panel in a     |
|     POWER UNLOCK|RED / blue            |-  |white 22 pin connector      |
|       LOCK MOTOR|blue/red            |   |drivers door harness        |
|     UNLOCK MOTOR|blue/white          |   |drivers kick panel *1       |
|    DISARM DEFEAT|blue                |   |passenger kick panel *2     |
| PARKING LIGHTS +|GREEN/ red           |   |drivers kick in a black plug|
| PARKING LIGHTS -|yellow or grn/yel *2|   |steering column             |
|       HEADLIGHTS|red or RED / blue *2  |-  |steering column             |
|     DOOR TRIGGER|RED / green           |-  |drivers kick in a white plug|
| DOME SUPERVISION|use door trigger    |   |                            |
|  TRUNK/HATCH PIN|tied in with door   |   |                            |
|         HOOD PIN|GREEN/ red           |-  |keyless module *3           |
|TRNK/HTCH RELEASE|lt. green           |   |keyless module *3           |
|  FCTRY ALARM ARM|purple *5           |-  |drivers kick in a white plug|
|FCTRY ALRM DISARM|yellow/blue *5      |-  |drivers kick in a white plug|
| DISARM NO UNLOCK|                    |   |                            |
|       TACHOMETER|BLACK/ red           |   |dkp, blk 22 pin plug, pin 4 |
|      SPEED SENSE|blue/black          |   |dkp, blk 22 pin plug, pin 2 |
|       BRAKE WIRE|red                 |+  |brake switch                |
|     HORN TRIGGER|green               |-  |steering column             |
|           WIPERS|blu/yel & blu/wht   |+  |steering column             |
|  LF WINDOW UP/DN|brn/wht - brn/red   |A  |drivers window switch       |
|  RF WINDOW UP/DN|brn/wht - brn/red   |A  |RF window switch            |
|  LR WINDOW UP/DN|brn/wht - brn/red   |A  |LR window switch            |
|  RR WINDOW UP/DN|brn/wht - brn/red   |A  |RR window switch            |
| SUN RF OPN/CLOSE|purple - blue       |A  |sunroof motor *4            |
|   SUN ROOF LIMIT|                    |   |                            |
|        RADIO 12V|RED / white           |+  |radio                       |
|     RADIO GROUND|black               |-  |radio                       |
|     RADIO SWITCH|RED / yellow          |+  |radio                       |
| RADIO ILLUMINATE|GREEN/ red           |+  |radio                       |
|       LF SPEAKER|blue - yellow       |   |radio or speaker            |
|       RF SPEAKER|green - gray        |   |radio or speaker            |
|       LR SPEAKER|orange - white      |   |radio or speaker            |
|       RR SPEAKER|orn/blu - orn/wht   |   |radio or speaker            |
Notes:
*1 In a white 10 pin connector  *2 Located up high in a white connector  *3 The keyless module is located to the right of the glove box.  *4 The sunroof motor is located in front of the sunroof in the headliner.  *5 Trigger the power lock and the factory alarm arm wires at the same time to arm the alarm.  Trigger the power unlock and the factory alarm disarm wires at the same time to disarm the alarm.
Derrik
Member - Posts: 46
Posted: November 02, 2002 at 12:26 PM / IP Logged
Thank you for much for the color codes. I was about to give up with the installation, after i heard it would cost me $160 ti have circuitcity to do it.
Posted: November 02, 2002 at 4:47 PM / IP Logged
No problem... good luck witht he installation.
