question for you box builders
beyma guy
Member - Posts: 16
Posted: August 20, 2004 at 11:00 AM / IP Logged
i have a box that i have already built and it sounds awsome but what i want to know is can it sound better it is almost 7 cubic feet for 2 12 inch subs and its ported the subs fire down and the port also fires down to the floor i want to leave the subs down firing but can better sound be made by changing the direction of the porting any and all help would be greatly app.
my system
4 beyma ast05 tweeters
4 beyma w6 mid drivers
2 beyma nd 105 mid drivers
2 clif design competion 12subs
2 cd1.1lx amps
2 cd4.4lx amps
1 cd5.2lx amp
hu is a pioneer dehp8500 mp
defective
Silver - Posts: 642
Posted: August 20, 2004 at 1:00 PM / IP Logged
a 7 cubic foot box!?!   for two 12"'s?!?!       I got a good idea to make it sound better, saw it in half.   I cant think of any subs that sound good in 3.5 cu/ft.
Forget about the ports.... if you want it to sound good, seal it.
vdubmk4
Copper - Posts: 175
Posted: August 20, 2004 at 1:56 PM / IP Logged
I thought correctly ported boxes are suppose to sound better ?
Beyma Guy, the down firing ports, are they flush against the floor or are they elevated like 2 or 3 inches ?
Fortune: You will continue to take chances, and be glad you did.
vdubmk4
Copper - Posts: 175
Posted: August 20, 2004 at 1:57 PM / IP Logged
Oh yeah, and defective is on to sometin, are you sure u need that much volume for your enclousure ??
kfr01
Gold - Posts: 2,121
Posted: August 20, 2004 at 2:54 PM / IP Logged
See this page:   http://www.diysubwoofers.org/
vdubmk4 said, "I thought correctly ported boxes are suppose to sound better ?"
It depends on your definition of 'sound better' and what application your subwoofer was designed for.  If greater output for the same amount of power is important to you and you have the space then a ported box can sound very good if properly constructed.
Sealed boxes require smaller enclosures and usually produce better transient response.  "They are usually the subwoofer system of choice for audiophiles because of their excellent transient response (i.e. no boomy sound) characteristics when designed and built properly."  diysubwoofers.org
New Project: 2003 Pathfinder
vdubmk4
Copper - Posts: 175
Posted: August 20, 2004 at 3:02 PM / IP Logged
Oh alright, thanks for clearin that up for me, i personally have always made sealed boxes, simply cause they are easier.
beyma guy
Member - Posts: 16
Posted: August 20, 2004 at 3:16 PM / IP Logged
THIS BOX WAS ACTUALLY DESIGNED BY CLIF DESIGN AS FAR AS THE AIR SPACE REQUIRMENTS THE BOX IS TUNED TO 30 HRZ AND YES IT DOES NEED THAT MUCH AIR SPACE THE PORTS ARE DOWN FIRING AS WELL THE PORTS AND THE SUBS ARE 5 INCHES FROM THE BOTTOM OF THE FLOOR WHAT I AM WONDERING IS CAN IT SOUND BETTER BY AIMING THE PORT FORWARD OR UPWARD HAD A SEALED BOX NEEDED MORE BASS SO THAT IS WHY I WENT PORTED AND THE SUBS DONT SHARE THE SAME CHAMBER THEY HAVE THERE OWN CHAMBERS AND PORTS THE SUBS I AM USEING ARE CLIF DESIGN 12 COMP SUBS WITH A CLIF CD1.1LX PER SUB
my system
2 cd1.1lx amps
2 cd4.4lx amps
1 cd5.2lx amp
kfr01
Gold - Posts: 2,121
Posted: August 20, 2004 at 3:24 PM / IP Logged
Caps alert.  Who knows if changing the port direction would help.  What sounds good in one car may not work in another.  The only way to know is to try it out.  Sorry I can't help more, but the characteristics of the car really determine how the bass waves are going to interact with the environment.
Maxst
Silver - Posts: 866
Posted: August 20, 2004 at 5:03 PM / IP Logged
clif design...that a shop...i saw a car that had a ton of clif design stuff on it.
try rotating the box around and see what you like.
If the ported box is built right, and tuned that low..its gonna be big...what you running?
I need quality equipment, feel free to donate.
defective
Silver - Posts: 642
Posted: August 20, 2004 at 10:01 PM / IP Logged
well it's great that you have a 'Clif Designed' box and everything..... but a box alone means nothing. if it's designed for an explorer, it might sound like crap in a civic.  That's why pre-fabs are a joke. Clif Designs is a prefab maker.
Alot more comes into play in box building than one really expensive box. Theres the dimensions/dynamics of a vehicle, interior plastic grades, etc.   The only way to make something sound good is to play with it, try doing your port idea, if it doesn't work, just put it back and fill the hole.
Have fun..... the term "if it ain't broke....." doesn't apply in car audio..... theres always something to play with for perfection.
Sunday, April 12, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
