99 dodge ram speakers?
mitchwffw
Posted: August 22, 2004 at 2:21 PM / IP Logged
Does any one know which speakers (aftermarket) 6x9 will fit my front doors? 99 dodge ram.  Will i need a install kit? Thanks
mo12v
Posted: August 22, 2004 at 8:18 PM / IP Logged
If using co-ax, tri-ax, quad-ax.......Just make sure you use a speaker that does not have a raised center section taller than the 6x9 cone area.  Some will cause the door panel to bow out
MO
Thursday, July 17, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
