first time install in a civic
flipkid187
Posted: August 22, 2004 at 9:14 PM / IP Logged
i currently have the clifford matrix 3 and i just got dont wiring everything but when i arm my car with the remote the following happens:  the car chirps and it tries to turn the engine on or turn over.  i dont have remote start (i dont think) but i dont know how to fix it.. any help will be greatly appreciated
draasch
Gold - Posts: 2,172
Posted: August 22, 2004 at 10:16 PM / IP Logged
lets start off the yr,make and model of car...........
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
Teken
Gold - Posts: 1,492
Posted: August 22, 2004 at 11:13 PM / IP Logged
Why are you asking him that? You do know your suppose to guess right . . . first time install in a civic -- posted image. Otherwise this would simply be too simple.
Regards
EVIL Teken . . .
flipkid187
Posted: August 23, 2004 at 12:40 AM / IP Logged
sorry.. im a newbie still. its a 97 honda civic. anyways i used the wrong wire for the parking lights.  i must of used the a starter or ignition wire.  i cant locate the correct one. its suppose to be RED / black.
draasch
Gold - Posts: 2,172
Posted: August 23, 2004 at 1:24 AM / IP Logged
7 pin connector @ fuse box
Good Luck
David
Ace Security
813-376-9778
Tampa
daniel2002p
Silver - Posts: 524
Posted: August 23, 2004 at 12:05 PM / IP Logged
it is at the back of fuse box.  take one 10mm bolt out and turn over.  i think that is where it is.
2005 Toyota Corolla S
    1.8L VVT-i I-4
Always double check your wires with a DMM!!!
Do Not Use A Test Light!!!
MECP Certified Installer!
Best Buy 665 - IN IT TO WIN IT! TEAM MOBLE!
