Disarm alarm 93 Grand Cherokee
at_or_not
Posted: August 23, 2004 at 5:41 PM / IP Logged
I bought a 93 Grand Cherokee and I got told to disarm the alarm is to turn the key first right then left. For unknown reason the alarm went off and I couldn't disarm it. I reclosed the doors and tried it a couple of times. Finally the horn stops but a security light is flashing and when I start the engine it stops shortly after (fuel cut?).
What can I do to use my car again?
at_or_not
auex
Platinum - Posts: 5,041
Posted: August 23, 2004 at 6:12 PM / IP Logged
Look under the dash for the alarm's "brain". Follow the wires down and you should find a couple of fuses; main power, parking lights, and probably locks. Pull the fuses out and you should be able to start the car.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Saturday, February 7, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
