I think I pooched my amp
Francious70
Silver - Posts: 629
Posted: August 23, 2004 at 10:31 PM / IP Logged
Well, I got my new Phoenix Gold amp in the other day, and installed it the exact same way my Pyramid was installed. Anyways, Friday I was going to pick up lunch, listening to my music at a lower level, when all of a sudden, I hear a thump, and then no bass. I turn off my HU and checked the amp when I got to where I was going, 5 seconds from where I was. All of the wires still plugged in. I checked the fuse, and sure 'nuff, it was blown. I think nothing about it, and go to Auto Zone to get some more fuses after work. Blows another. I unplug the amp, just to be safe. Bout a new wiring kit yesterday, wired it up, and blew that fuse too. Took the amp out of the car, took the cover off, and didn't see anything burnt, so I put the cover back on. The amp is still unpluged, and I am still pissed.
So, my question is, is the amp pooched, or is it somthing else??
Paul
auex
Platinum - Posts: 5,041
Posted: August 23, 2004 at 10:33 PM / IP Logged
Doesn't sound good. Try disconnecting the speakers and turn the amp on to see if it still blows the fuse.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Francious70
Silver - Posts: 629
Posted: August 23, 2004 at 10:51 PM / IP Logged
Will do. And I don't like to hear, "Doesn't sound good." I think I pooched my amp -- posted image. If it does blow a fuse what does that mean??
Paul
auex
Posted: August 23, 2004 at 11:01 PM / IP Logged
If it blows the fuse when the speakers are disconnected then more then likely the amp is blown, if it doesn't blow then one of your subs may be bad. It would be good if you have a warranty.
Francious70
Silver - Posts: 629
Posted: August 23, 2004 at 11:42 PM / IP Logged
I wish I did. I bought the sub off e-bay a year ago. I bought the amp from e-bay but already returned one for doing the same thing.
Paul
haemphyst
Platinum - Posts: 5,059
Posted: August 24, 2004 at 9:08 AM / IP Logged
ah... now we are on to something. you returned another one for doing the same thing? check first, the way the woofer is wired... is it DVC or single, series or parallel, bridged or stereo load? then, have you checked the POWER LINES to the amp? are you certain you are getting enough power to the amp in the first place? check all of your connections, from the battery back to the amp, and from the amp to the chassis ground. I bet you might find something in these suggestions.
dragonrage
Copper - Posts: 193
Posted: August 24, 2004 at 9:12 AM / IP Logged
Is the fuse on the amp or the fuse in the wiring kit blowing? If it's on the wiring kit, you may have crossed power wires. If on the amp only, then you may be overloading the amp, possibly due to crossed output wires. A bad ground MIGHT also cause this. I don't know how good Phoenix Gold is with their protection circuits, so I can't really tell you much for sure.
2009 Pontiac G8 in planning stage
HU: ?
Speakers: ?
Amps: ?
DYohn
Platinum - Posts: 10,741
Posted: August 24, 2004 at 9:54 AM / IP Logged
Sounds like you are either running too low an impedence, your gain is set too high, or both.  When you swapped amps, did you properly set up the new amp or just "plug it in?"
Francious70
Silver - Posts: 629
Posted: August 24, 2004 at 10:57 AM / IP Logged
As a reply to all of your posts. Umm... yes??
haemphyst:
it's a DVC, wired in with one VC on each channel. The amp is a mono-block internally wired in parallel. As for the power wires, I completely redid the power wires. Bigger wires, and this time, instead of mounting the ground to the body, I bolted it to the frame. That should be under .5 ohms.
dragonrage:
It's the fuse on the wire. The amp its self dosn't have a fuse. I was kinda puzzled to find that out. And what do you mean by crossing output wires??
DYohn:
The impedence is 2 ohms, and the amp is 1 ohm stable. Gain is set at mid. And when I installed the amp, I made sure to turn the gain all the way down, the bass boost all the way down, and set the crossovers at a safe level, then tuned them all to where they sounded good.
Paul
DYohn
Posted: August 24, 2004 at 11:28 AM / IP Logged
OK then.  Did you try to activate it with no speakers conencted?  Sorry to say if it blows with nothing connected and you have a good power and ground, it may very well be a defective amplifier.  Is it a factory refurb?  Thank you eBay!
