2004 Merc. sable
erc1
Posted: August 28, 2004 at 10:25 PM / IP Logged
Does anyone have any wiring on instaling a remote starter. Thank You Rick
Bnluis
Silver - Posts: 578
Posted: August 28, 2004 at 10:39 PM / IP Logged
Mercury
Sable
2004
Remote Starter Wiring Colors and Notes
Function
Vehicle Color
Location
Start:
RED / Lt.Blue (+)
Ignition switch harness
Ignition #1:
RED / Lt.Green (+)
Ignition switch harness*
Ignition #2:
N/A
Ignition #3:
N/A
Accessory:
Gray / YELLOW (+)
Brake Light:
RED / Lt.Green (+)
Brake pedal switch
Tach Signal:
Tan / YELLOW (AC)
At the PCM**
Parking Lights:
Brown (+)
Headlight switch or fuse box
Headlights:
N/A
OEM Alarm Disarm:
Pink/White (-)
Harness at the GEM module***
OEM Alarm Arm:
N/A
Diesel Glow Plug:
N/A
Clutch Bypass Wire:
N/A
Notes:
*This car may be equipped with a Transpond Anti-Theft Security System. Use Universal Alarm Bypass Module part # 2x402 where X can be any number. **The Powertrain Control Module is on the passenger side firewall under the hood. ***The Generic Electronic Module (GEM) is to the left of the steering column.
Mercury
Sable
2004
Alarm and Keyless Entry Wiring Colors and Notes
Function
Vehicle Color
Location
Constant +12 Volts:
Lt.GREEN/ Purple (+)
Starter Kill:
RED / Lt.Blue (+)
Ignition +12 Volts:
RED / Lt.Green (+)
Dome Lights/Superv:
BLACK/ Lt.Blue (+)
Top plug of the fuse box
OEM Horn:
Purple or Blue (-)
Steering column harness
Power Lock:
Pink / YELLOW (-)
At the GEM module****
Power Unlock:
Pink/Lt.Green (-)
Trunk Release:
N/A
Alarm Input Wire:
BLACK/ Lt.Blue (+)
Notes:
****The Generic Electronic Module (GEM) is to the left of the steering column. See Note #201 Negative Trigger Door Locks
Luis
Sound Waves
Is up to the installer to test all wires with a DMM whenever possible.
erc1
Posted: August 29, 2004 at 7:23 PM / IP Logged
Thank You,  Rick
