3.5 remote issues
nyguy4u
Copper - Posts: 148
Posted: August 28, 2004 at 10:38 PM / IP Logged
had a matrix 3.5 installed in my car roughly 3 months ago. Never had a problem. All of a sudden though, something is weird with the remote. It lost half it's volume, and when the doors are locked, the lock is unlocked on my remote, and vice versa when the doors are unlocked, the status on the remote says its locked.
Is there a way to reset the remote?. I changed the batts, so that isn't the issue. I was thinking maybe if I keep the battery out of the remote for a few hrs, that would reset it?
Any ideas?
kgerry
Platinum - Posts: 3,455
Posted: August 30, 2004 at 12:18 PM / IP Logged
you could try to clear all transmitters and re-learn it....
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
nyguy4u
Copper - Posts: 148
Posted: August 30, 2004 at 11:25 PM / IP Logged
how do I do that?
kkeeni
Member - Posts: 20
Posted: August 30, 2004 at 11:40 PM / IP Logged
make shure your door trigger wire is hooked up, and your igniton wire.open a door, turn the key on, press and release the valet button 10 times then hold it the 11 time , and press any button. it should be deleted.turn the key off. then repeat the process only this time hold the valet button on the 9 time, should auto learn the remote.
kgerry
Posted: August 31, 2004 at 10:06 AM / IP Logged
if i'm not mistaken the 3.5 auto learns on 1 not 9 now... i just did one last week
yep, just checked the install manual.... 12 will "delete all transmitters" and 1 will "Auto Learn Standard Configuration*"
Kevin Gerry
Owner/Installer
Classic Car Audio
since 1979
nyguy4u
Copper - Posts: 148
Posted: August 31, 2004 at 10:15 AM / IP Logged
ok, so what do I do?
first step would be to press the valet button 10 times and hold on the 11th?
and for the second, instead of repeating it and and holding it on the 9th, I just press and hold 1 time?
kgerry
Posted: August 31, 2004 at 12:06 PM / IP Logged
who installed this unit? why not just take it back to them andf get them to trouble shoot it for you.......
Kevin Gerry
Owner/Installer
Classic Car Audio
since 1979
nyguy4u
Copper - Posts: 148
Posted: August 31, 2004 at 12:14 PM / IP Logged
I did, they said it was a defective transmitter. Only reason because, the "beeping" that the transmitter makes when you unlock and lock the doors is half its normal volume.
kgerry
Posted: August 31, 2004 at 2:13 PM / IP Logged
so why didnt they replace it if they sold and installed the unit for you?? that's certainly what we would do.....
Kevin Gerry
Owner/Installer
Classic Car Audio
since 1979
nyguy4u
Copper - Posts: 148
Posted: August 31, 2004 at 3:28 PM / IP Logged
I didn't buy it from them. I work for Best Buy, and I got it from DEI direct under an accomodation program.
Getting back to the question, what exactly do I need to do to reset the transmitter?
