93 Mustang power door lock wiring
BeastMn37
Posted: September 20, 2002 at 6:39 PM / IP Logged
I have a 93 mustang and am trying to figure how to wire the power door lock wiring to my alarm. I have a Gargoyle CS-2003DC alarm and I know that it is a reverse polarity door lock system. I also need to know how to wire the relays. Any help would be appreciated. In my instuction manual I have 4 wires to connect. A white wire(door lock){switch side, term 87A]. A green wire(door lock output)[motor side, term 30]. A blue wire(door unlock output)[motor side, term 30. And a brown wire(door unlock)[switch side, term 87A]. How would I match that up with relay diagram. It doesn't seem to match. It looks more like the 5 wire positive door lock diagram from what the picture shows in my manual. The manual just doesn't say how to use the relays.
Platinum - Posts: 12,488
Posted: September 20, 2002 at 7:47 PM / IP Logged
https://www.the12volt.com/doorlocks/page3.asp#arp
SnomanF150
Silver - Posts: 269
Posted: September 20, 2002 at 8:55 PM / IP Logged
you got to find the lock and unlock wires first.. pink / YELLOW for lock, pink/green for unlock... get those wires.. easiest in the kick panel or doorjam.. cut both wires and that will give you the four wires you need to get.. you will have a switch side and motor side.. the switch side will have 12v+ when you hit the switch (door locks will not work with the wires cut, duh)  connect your WHITE wire to pink / YELLOW switch side,  GREEN wire to pink / YELLOW motor side,  BROWN wire to pink/green switch side, and BLUE wire to the pink/green motor side.  these wire are from the on-board relays in the brain itself..
good luck
Wednesday, April 15, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
