after installation, backlighting out
cslamirand
Posted: August 30, 2004 at 11:56 AM / IP Logged
I succesfully installed a new CD player in a 1999 4runner. However now the backlighting for my dash(speedometer, tach etc) is out. Is this connected to the stereo somehow?? or perhaps fuse too low amp. help?
chris
kgerry
Platinum - Posts: 3,455
Posted: August 30, 2004 at 12:38 PM / IP Logged
you probably used the dash light wire as a ground... it will meter to ground until you turn on the parking lights, at which point it'll zap the fuse....
you may want to check for this..... or a bare dimmer wire touching the chassis of the radio at the back
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
Alpine Guy
Platinum - Posts: 2,478
Posted: August 30, 2004 at 2:49 PM / IP Logged
check your dimmer wire, disconnect it from the deck harness if you wired it up.  It could be a fuse, ,or the dimmer switch is set to off, or its blown $200....
cslamirand
Posted: August 30, 2004 at 5:40 PM / IP Logged
Thanks ... I did hook up the dimmer switch so I am going back in to disconnect it and see if that helps. I checked the fuses and they look good, plus everything else on that fuse works. I hope it is not blown, just bought the truck. It is still under warranty with carmax, but I have a feeling that they would blame the stereo installation and make me pay if it is blown.
thanks again...
chris
Alpine Guy
Posted: August 30, 2004 at 11:14 PM / IP Logged
if its blowen, ,just remove the stereo and put the factory back in before you bring it in to get fixed.
Friday, December 19, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
