poor range
muaiad97
Copper - Posts: 207
Posted: August 31, 2004 at 8:02 PM / IP Logged
 i installd remot starter with alarm  band  autostart 1424 in dodge intrepid
but its very poor  range  i have to go very close to car to  start the car or lock  unlock the doors  i conected all wires right  .
thanx
auex
Platinum - Posts: 5,041
Posted: August 31, 2004 at 8:28 PM / IP Logged
Make sure the antenna is not bundled up with any power wires.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
dfiddy
Copper - Posts: 162
Posted: August 31, 2004 at 9:50 PM / IP Logged
Start with the basics, make sure your ground is good, next check and see if the antenna is pinched, maybe even switch the antenna location and see if that makes a difference. You could also run a new antenna just loosly over top of panels to help eliminate any problems (just for testing of course).
mo12v
Posted: August 31, 2004 at 10:09 PM / IP Logged
U might try the temporarally putting the antennea outside and see if U get better results...............If U do U may have interference from other devices in vehicle i.e. Keyless Entry, ECM, BCM, etc.  Then U may have to contact tech service of autostart & see what they recommend.  Some Units U can ground anteena for better reception and others is trial & error
MO
auex
Posted: August 31, 2004 at 10:13 PM / IP Logged
I hope you meant ground the shielding of the antenna.
mo12v
Posted: August 31, 2004 at 10:17 PM / IP Logged
That's a YEP
MO
