AutoStart model as-1200
mat_boy
Posted: September 21, 2002 at 8:01 PM / IP Logged
I need the to know where is terminal on the as-1200 unit is the Out when running. Please help
in order i know
question mark mean that i dont know,
gnd, tach, hood pin, glow, brake, 12v valet, parking lt, door, door, trunk, ?,  external trigger, ?, ? ,? ,
AutoStart info are not easy to find on the net! I just get the as-1260 wiring diagram (for manual transmission)
Mat_Boy
Platinum - Posts: 12,488
Posted: September 21, 2002 at 9:22 PM / IP Logged
It should be the ORANGE wire on the 14 pin harness.
tech_advice
Member - Posts: 45
Posted: September 22, 2002 at 12:22 PM / IP Logged
It's in the four pin harness closest to the antenna jack, and it's, external trigger(brown), out when running(green), re-arm(blue) and disarm(white)....hope this helps...
Don't share too many install secrets with your customers, pretty soon they won't need you!!!!!
Posted: September 22, 2002 at 9:16 PM / IP Logged
WOW was I way off !! AutoStart model as-1200 -- posted image. Sorry for the bad information. I got this from the UltraStart site .... my bad AutoStart model as-1200 -- posted image.
