decrease in remote range
docfnky
Member - Posts: 13
Posted: September 02, 2004 at 4:42 PM / IP Logged
hey guys, i have a basic viper car alarm....it's been installed since 2001 and everything works fine...just that now to use the remote i have to be practically next to the car...is there anything that i can do to get the same range as when it was new?
slicksam
Copper - Posts: 291
Posted: September 02, 2004 at 4:49 PM / IP Logged
change the battery in the remote
or try another remote.
make sure the antenna of the alarm is close to the window
Testing is the key
redlight831
Copper - Posts: 59
Posted: September 02, 2004 at 7:34 PM / IP Logged
i have the same problem i replaced the battery and no change...i just dont have another remote to try
sparkie
Platinum - Posts: 2,061
Posted: September 02, 2004 at 8:24 PM / IP Logged
Use a volt meter and check to see that the new battery is indeed good. You would be suprised how many times a new battery is garbage. Radio Shack seems to only sell dead batteries. Adding window tint to the car will also reduce your range. If the problem occurred gradually, then the remote could be wearing out. If it happened suddenly, was any work done on the car recently? Maybe the antenna has come unplugged. Locate a dealer and have them try a new remote.
sparky
kgerry
Platinum - Posts: 3,455
Posted: September 04, 2004 at 2:46 PM / IP Logged
sounds like a ground issue to me.... most of the DEI units with poor range after a year or two  are poor ground problems.....
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
