2004 civic lock control
mikelo
Member - Posts: 18
Posted: September 07, 2004 at 12:47 AM / IP Logged
Please give me help on the control of lock and unlock.
Both the lock and unlock wires are found, but those wire can neither control by positive nor negative.
mikelo
profuse007
Gold - Posts: 2,015
Posted: September 07, 2004 at 12:58 AM / IP Logged
if i recall, the wire is w/ a green plug hanging up high left of dash. two wire harness.
Houston,TX
Xmc Sam
Member - Posts: 19
Posted: September 16, 2004 at 2:42 AM / IP Logged
Gray plug at drivers kick panel(right above it) do not need to remove, WHITE/ green and WHITE/ blue
first two wires on connector. Door lock will not work if door is opened, only unlock. Must close doors and remove key from switch to test.
profuse007
Gold - Posts: 2,015
Posted: September 16, 2004 at 2:47 AM / IP Logged
actually all hondas have self-lockout protection. you can lock it if you pull the interior handle.
Houston,TX
Wednesday, September 10, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
