05 Scion TC python 881xp Remote Start?
Dj adapt
Posted: September 07, 2004 at 5:17 PM / IP Logged
I was wondering if anyone has any info they would like to share about this new vehical. I have unsucessfully installed a Python 881XP, I got the alarm to work, but the remote start portion was a total failure. I thought the wiring would be similar to other toyota's or even the scion xa or xb, but it is not. My biggest question comes in the form or where I should connect the pink igintion wires? The scion TC has 3 heavy gauged wires in the ignition harness Black "???" RED "???" Blue "???" along with some other smaller gauge wires. I tried many different configuations but only got it to crank, but not catch. Has anyone ever seen this type of toyota/ scion configuartion or can recommend how to connect the dei relay pack to it. I have a 2000 tacoma that I installed a viper 550esp to, and the igintion harness looks different, it had the traditional BLACK / YELLOW ignition wires, etc. There is a factory key-less entry installed, but no alarm or starter disable functions. It's a real pain having this vehical, because I want to do so many mods, but lack of info and parts makes it fustrating. I have unsucessfully added a D2R Hid light system, too much glare, need projectors, sucessfully added a Zapco I-Force 450 amp, "using speaker level inputs", 10" Boston pro in a .75 ft3  q-logic wedge enclosure.
THANKS
auex
Platinum - Posts: 5,041
Posted: September 07, 2004 at 5:36 PM / IP Logged
05 Scion TC Security/remote start
Audio
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
Dj adapt
Posted: September 07, 2004 at 6:32 PM / IP Logged
AUEX YOU ARE THE MAN.
I will try out the information this evening when I get home from work.
Once again, many Thanks!!!
