2004 maxima remote start install
nuconcepts
Posted: September 08, 2004 at 2:00 PM / IP Logged
Looking for the diagram to install a 3300 Avi-start made by DEI, thanks!
auex
Platinum - Posts: 5,041
Posted: September 08, 2004 at 4:55 PM / IP Logged
Avital 3300 Install manual.
04 Nissan Maxima
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
nuconcepts
Posted: September 28, 2004 at 8:58 PM / IP Logged
You are my god!!!! I did not even read this before i posted, but you rule. Does the 555 need to be a 3 wire one (red-blue-white) or just a signal from the coil with two wires? Thanks again...Any thing funny with this one, I've done many others, first maxima
Platinum - Posts: 12,488
Posted: September 28, 2004 at 9:10 PM / IP Logged
The Maxima uses 2 starter wires, unlock requires 2 pulses, and the universal bypass module.
nuconcepts
Posted: September 28, 2004 at 9:17 PM / IP Logged
so 12v+ and the trigger, No key sence......How long you think for the avrage installer? Easy to get the pannel off from the door for the locks?, Thanks for all your help you rule!!!!
JWorm
Platinum - Posts: 2,208
Posted: September 29, 2004 at 12:37 AM / IP Logged
You can get the doorlocks inside the car. I did it on an 05 Maxima yesterday (with factory alarm), It requires you to add 2 wires to the BCM where there are empty pins. Check out http://www.carsound.com/UBB/ultimatebb.php?ubb=get_topic;f=3;t=002070    for details.
nuconcepts
Posted: September 29, 2004 at 1:31 AM / IP Logged
Now if they onlky had a tach signal inside the car.
