What is PCM mean
clovesb4ever
Member - Posts: 12
Posted: September 08, 2004 at 4:33 PM / IP Logged
Can anyone tell me what PCM stands for regarding the message below.
VSS brown ac pcm, 23 pin black plug   Notes: The PCM is behind the driver side headlight
auex
Platinum - Posts: 5,041
Posted: September 08, 2004 at 4:40 PM / IP Logged
Powertrain control module, and it is near the "headlight" not the "headlight switch", and is in the engine compartment. If it was near the "headlight switch" it would have stated that specifically. Usually you can take what is stated as location the location, this info is genarally specific.
Certified Security Specialist
I promise to be good.
Tell Darwin I sent you.
