Alarm? Starter Motor? Help...
goldf1ng3r
Posted: September 23, 2002 at 9:07 AM / IP Logged
Hi,
Im having some problems with my 95M Clio 16v. I have a Clifford Concept 300 alarm fitted and when I tried to disable it yesterday it started making some very starnge screeching noises.
After phoning the alarm guys they seem to think it may be that my starter motor is dodgy/broken. They came to this conclusion as when I finally managed to disarm the alarm and tried to fire it up it made a quiet repetative clicking sound, coming from beside the key.
The alarm guys seem to think that a faulty starter motor would cause the alarm to malfunction, as they are in the same elctrical loop??
Another thing that I have noticed recently (unrealted?) is that the rear windscreen wiper switch is intamitant, making me think that there are some loose connection somewhere?
As you've probably guessed I dont know a lot about the electrics behind these things, and would appreciate some comments! eg. does the fault starter motor scenario sound feasable?
Cheers.
Moderator - Posts: 12,488
Posted: September 23, 2002 at 9:22 AM / IP Logged
Have you disabled the alarm system compeltely ( unplugg the harness ) and see if the problem persists ? Doesn't sound like it's a problem with the alarm system. The only thing the alarm system would be attached to would be the starter disable relay ( unless it wasn't attached ).
Thursday, December 25, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
