1994 toyota camry sedan, rear speakers
jare
Member - Posts: 12
Posted: September 10, 2004 at 6:12 PM / IP Logged
I want to replace the rear factory speakers,but don't know how to take a part that part of the car. any instruction available? thanks.
shadowinfector
Copper - Posts: 199
Posted: September 11, 2004 at 9:21 PM / IP Logged
first take off the weather stripping in the middle hole when you drop your rear seats then pop off the two rear side panels and the brake light panel.....after the brake light there should be 2 10mm bolts holding it ...remove those and disconnect the brake light. the two side cushions have to be removed...these are really hard...u have to pull up and outward....after that the rear deck should just come out
