Bluetooth
Professor
Posted: September 16, 2004 at 7:46 PM / IP Logged
Has anybody had any experience using Bluetooth in a custom setting? I need to convert a wired headset to wireless if possible.  I want to install it on a motorcycle.  It would need to be duplex to be able to transmit two audio channels, left and right, as well as the microphone signal.  The transceiver in the helmet would need to be very small with an inexpensive battery.  The other could be a bit larger and connect to an external power source
Professor
Posted: September 16, 2004 at 7:49 PM / IP Logged
That looks nasty! I'll try it again.
Has anybody had any experience using Bluetooth in a custom setting? I need to convert a wired headset to wireless if possible.  I want to install it on a motorcycle.  It would need to be duplex to be able to transmit two audio channels, left and right, as well as the microphone signal.  The transceiver in the helmet would need to be very small with an inexpensive battery.  The other could be a bit larger and connect to an external power source.
You can vote in polls in this forum
