disable factory alarm
MX6boii
Copper - Posts: 74
Posted: September 18, 2004 at 11:14 AM / IP Logged
Hi, does anyone know how to disable the factory alarm on a '98 Intrepid ES?
Thanks.
profuse007
Gold - Posts: 2,015
Posted: September 18, 2004 at 2:08 PM / IP Logged
|FCTRY ALRM DISARM|lt. GREEN/ orange    |+ |drivers kick panel          |
no need to disable factory alarm, just disarm it.
Houston,TX
MX6boii
Copper - Posts: 74
Posted: September 18, 2004 at 10:33 PM / IP Logged
Yes, I know of that wire and have tried to disarm it that way with no luck. I have a remote start system that delivers a negative for the factory alarm shutdown. I installed a relay and it still doesn't work. I even tested to see if I had the correct lt.GREEN/ orange wire since there seems to be another wire similar to that color in that stash of 50 wires. If I remember right when the alarm is armed that wire will have 12V power. Once disarmed it won't have any. The only reason I'm messing with this again is because I did the installation for a friend and he said the alarm went off some how by the remote start.   disable factory alarm -- posted image. He asked if there was a way to disable the alarm. Right now he has to disable the alarm and then remote start the car. Since it has been a few months since I messed with it, I'll attempt using the lt.GREEN/ orange wire again. I'm just looking for an easier way out if I fail again, haha.
Thanks.
Saturday, November 1, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
