94 Acura Integra alarm wiring
kustomizer
Posted: September 19, 2004 at 8:00 PM / IP Logged
Hi I am installing an Otion car alarm in a 94 Acura Integra.  The alarm calls for input power from the hazards and the alarm also has 2 input wires for that and I was wondering if anyone can help me on that and also where does the wire that says dist. go and if anyone can help me with this it would be appreciated greatly. If the door locks are neg.  do i need the 2 relays for this? I am not an expert at this and any help is greatly appreciated.
thanks-kustomizer
Teken
Gold - Posts: 1,492
Posted: September 19, 2004 at 8:16 PM / IP Logged
Acura
Integra
1994-1995
Remote Starter Wiring Colors and Notes
Function
   Vehicle Color
Location
Start:
   BLACK/ WHITE
IGNITION SWITCH HARNESS
Ignition #1:
   BLACK / YELLOW
Ignition #2:
   YELLOW
Ignition #3:
   N/A
Accessory:
   WHITE/ BLACK
Brake Light:
   GREEN / WHITE (+)
AT SWITCH ABOVE BRAKE PEDAL
Tach Signal:
   BLUE
AT DISTRIBUTOR*
Parking Lights:
   RED / BLACK (+)
GREEN CONNECTOR AT FUSE BOX**
Headlights:
   RED / WHITE (LO)
RED / BLUE (HI) AT HEADLIGHT SWITCH (+)
OEM Alarm Disarm:
   N/A
OEM Alarm Arm:
   N/A
Diesel Glow Plug:
   N/A
N/A
Clutch Bypass Wire:
   N/A
N/A
Notes:
   * Distributor Located On Passenger Side Of Engine. Tach Test Connector Is a 2 Pin GRAY Connector Located On Driver Rear Of Engine On Strut Tower. Tach Wire Also Located In 16 Pin GRAY Connector Above Fuse Block Behind Driver Dash.
Acura
Integra
1994-1995
Alarm and Keyless Entry Wiring Colors and Notes
Function
   Vehicle Color
Location
Constant +12 Volts:
   WHITE
Starter Kill:
   BLACK/ WHITE
Ignition +12 Volts:
   BLACK / YELLOW
Dome Lights/Superv:
   LIGHT GREEN/ RED (-)
BLUE CONNECTOR AT FUSE BOX
OEM Horn:
   BLUE/GREEN (-)
AT RELAY ON LEFT SIDE OF FUSE BLOCK
Power Lock:
   BLACK/ WHITE
IN LARGER OF 2 GRAY CONNECTORS***
Power Unlock:
   BLACK/ RED
BEHIND CRUISE MOD IN DRIVER KICK PANEL
Trunk Release:
   N/A
Alarm Input Wire:
Notes:
** RED / BLACK (+) In 18 Pin BROWN Connector In Driver Kick Panel Can Also Be Used For Parking Lights. *** See Note #201- Negative Pulse Door Lock Diagram.
