2002 Stratus R/T
jaurora
Silver - Posts: 429
Posted: September 20, 2004 at 2:10 PM / IP Logged
Can someone please help me out with a tech sheet for this car. It is a 2002 Dodge Stratus R/T. Thank you very much as it is always appreacated.
MECP certified (If it really means anything)
Jeremy
draasch
Gold - Posts: 2,172
Posted: September 20, 2004 at 2:13 PM / IP Logged
sedan or coupe??
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
jaurora
Silver - Posts: 429
Posted: September 20, 2004 at 2:59 PM / IP Logged
Its the Road and Track version, 2dr, so I am guessing coupe
Jeremy
snguyen
Silver - Posts: 281
Posted: September 21, 2004 at 8:28 PM / IP Logged
Remote start / Security / GPS
Wire/FunctionColourLocation/DescriptionPolarityPic/Graphic
PASSIVE ANTI-THEFT
YES TRANSPONDER SEE NOTES
12 VOLTS
WHITE/ red Ignition switch harness +
IGNITION
Dk.green or BLACK/ white Ignition switch harness +
ACCESSORY
Blue/black Ignition switch harness +
ACCESSORY 2
Blue or Blue/red Ignition switch harness +
STARTER
BLACK/ red Ignition switch harness +
TACH
RED / green At coil on top of engine AC
FUEL INJECTOR
Opposite of BLACK/ red At any injector on engine AC
LOCK
Lt.GREEN/ black On 32-pin plug in driver's kick -
UNLOCK
Orange On 32-pin plug in driver's kick -
DOORPIN
GREEN/ YELLOW In plug on left side of fusebox -
TRUNK PIN
RED / green In driver's kickpanel -
SUN ROOF OPEN
Blue*
At sun roof switch -
SUN ROOF CLOSE
Blue/red*
FACTORY ARM
Arms with lock wire
FACTORY DISARM
Disarms with unlock wire**
BRAKESWITCH
Green At switch above brake pedal +
PARKLIGHTS
GREEN / WHITE Pin-11 of 20-pin plug on front of fusebox +
HAND BRAKE
Yellow/black At switch on handbrake elver -
HORN
GREEN/ black At steering column -
DRIVER WINDOW UP
GREEN/ red At switch in driver's door REV POL
DRIVER WINDOW DOWN
GREEN/ black At switch in driver's door REV POL
PASSENGER WINDOW UP
BROWN / yellow At switch in passenger door REV POL
PASSENGER WINDOW DOWN
GREEN/ YELLOW At switch in passenger door REV POL
HEADLIGHTS
Red At light switch harness -
REVERSE LIGHTS
RED / blue At fusebox below driver's side of dash +
DIMMER
BLACK / YELLOW At dimmer switch in dash +
VSS WIRE
Yellow/white Pin-66 on PCM in front of battery 8000ppm
KEY SENSE
GREEN/ YELLOW Ignition switch harness -
? Vehicle notes
PLEASE NOTE: If the ignition keys are GRAY, the vehicle is equipped with an IMMOBILIZER passive anti-theft system. See the appropriate security diagram for bypass instructions.
* You must simultaneously energize the ignition to operate the sunroof through these wires.
** A double pulse to this wire will unlock the doors.
