Clifford G5 Arrow 5 for C-Class?
Htfan1
Member - Posts: 6
Posted: September 22, 2004 at 6:52 PM / IP Logged
I'm new to this forum and already very impressed with the knowledge here!
I'm considering a Clifford G5 Arrow 5 for my 1995 Mercedes C220.  However, I'd like the forum's input prior to purchasing and installing the unit.  (BTW, I don't need remote start.)  I'm primarily looking for a solid basic alarm.
Will this unit work with the vacuum door locks?
Are there wiring diagrams available for the C220 or any other information for installing this alarm specifically in my car?
I appeciate any assistance!
Teken
Gold - Posts: 1,492
Posted: September 22, 2004 at 7:35 PM / IP Logged
Mercedes-Benz
C Class
1994-1997
Alarm and Keyless Entry Wiring Colors and Notes
Function
   Vehicle Color
Location
Constant +12 Volts:
   RED
IGNITION SWITCH HARNESS
Starter Kill:
   VIOLET
Ignition +12 Volts:
   PINK/RED
Dome Lights/Superv:
   FRONT - BROWN / GRAY
REAR - BROWN / GRAY / YELLOW DOTS BOTH(-)
OEM Horn:
   BLACK OR BROWN / BLACK
(-) STEERING COLUMN HARNESS
Power Lock:
   BLACK
DRIVER'S KICK PANEL ***
Power Unlock:
   BLUE
Trunk Release:
   VIOLET
AT TRUNK RELEASE SWITCH
Alarm Input Wire:
Notes:
** Split Parking Light System - must use relays to isolate the circuits from each other.. Diode Isolate Each Wire. *** See Note #201 - Negative Pulse Door Lock Diagram
Teken
Gold - Posts: 1,492
Posted: September 22, 2004 at 7:37 PM / IP Logged
http://www.designtech-intl.com/Content/techsupport/documents/section04/note201.pdf
This will show you how to wire your door locks.
Regards
EVIL Teken . . .
Teken
Gold - Posts: 1,492
Posted: September 22, 2004 at 7:48 PM / IP Logged
http://www.directechs.com/guides/manuals/ig/clifford/N909595_3-03.pdf
This is the installation manual for the alarm in question, assuming you are selecting this one.
Regards
EVIL Teken . . .
kgerry
Platinum - Posts: 3,455
Posted: September 23, 2004 at 1:01 PM / IP Logged
you know.... Clifford makes a great product... and you certainly cant go wrong with the G5 stuff.....
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
Htfan1
Member - Posts: 6
Posted: September 23, 2004 at 3:21 PM / IP Logged
Great information!  Thank you for all the feedback.
A couple more questions popped up.
1) Door locks: Do I use the procedure documented for vacuum locks in the Arrow 5 installation manual (and this website) or use the information in note201.pdf above? (They seem very different.)
2) Alarm wiring information above: Are these the recommended wires I use for a Clifford (or other non-Mercedes) alarm installation, or are these the wires used for a mercedes factory alarm?
3) Clifford 509-U interior sensor: I like the option of protecting entry to the car through an open sun roof or window.  What information is available for this sensor?  Any experiences out there that you can share? (I've had something similar on another car with an Alpine alarm - 8058 I believe.)
Again, I appreciate any feedback provided!
Teken
Gold - Posts: 1,492
Posted: September 23, 2004 at 7:44 PM / IP Logged
1. Use the information as it pertains to vacuum locks.
2. These are the exact wires which you need to interface to the vehicle so as the alarm will function. It is indeed specific to your vehicle.
3. I do not have any information as it pertains to this device.
Regards
EVIL Teken . . .
Htfan1
Member - Posts: 6
Posted: September 24, 2004 at 3:19 PM / IP Logged
Thank you again!
I was wondering about one other thing.  The vacuum lock doucmentation mentions a single wire that changes polarity depending on lock status.  However, the wiring info mentions two wires:
Power Lock:
   BLACK
Power Unlock:
   BLUE
Can I use either wire for this purpose?  Or do I need to locate a different wire for the vacuum pump?
Thanks,
Tuesday, February 17, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
