98 ram dome light trouble
c tech
Posted: September 22, 2004 at 7:50 PM / IP Logged
I have a 99 dodge ram after installing a headunit the dome, cargo, under hood, and the upper light wont turn on, also the radio does not have memory.  what can I check or do ti fix this problem.
mo12v
Posted: September 22, 2004 at 8:00 PM / IP Logged
Fuse in Fuse panel.... I think it is Dome light.  Otherwise check main fuse under hood from battery accessory.
MO
