2004 dodge ram 3500 diesal
amador
Copper - Posts: 108
Posted: September 23, 2004 at 2:35 AM / IP Logged
ello everyone i am in need of some help once again i have a alarm to do in a dodge ram 3500 diesal and need a wire diagram for this truck please do help thanks everyone
amador
Copper - Posts: 108
Posted: September 24, 2004 at 2:32 AM / IP Logged
i guess no one has any info here well thats a first
draasch
Gold - Posts: 2,172
Posted: September 24, 2004 at 2:53 AM / IP Logged
here is what i have....double check with a meter.....
Make:   Dodge
Model: Pickup - Fullsize
Year:    2004
Alarm
Constant 12 volts RED (USE LARGER) IGNITION SWITCH HARNESS
Ignition 12 volts PINK/WHITE IGNITION SWITCH HARNESS
Starter YELLOW IGNITION SWITCH HARNESS
Dome Light YELLOW /GREEN (+) AT DOME LIGHT
Trunk Pin Switch
Parking Lamp WHITE/ GREY DRIVER KICK PANEL *
Power Lock VIOLET/GREEN DRIVER KICK PANEL ** #217
Power Unlock SINGLE WIRE SYSTEM DRIVER KICK PANEL **
* Has Also Been Reported As BROWN (+) At Parking Light Switch ** VIOLET/GREEN Wire Must See Ground Through 887 Ohm Resistor For Lock And Ground Through 280 Ohm Resistor For Unlock. #217 See Single Wire Resistor Door Lock Circuit Diagram
Accessories
Window Up
Window Down
Ign Key Warn BLUE (-) IGNITION HARNESS
Trunk Release
OEM Horn DK GREEN/ VIOLET (-) STEERING COLUMN HARNESS
Headlights
OEM Alarm Arm VIOLET / YELLOW (-) THROUGH 480 OHM RESISTOR DRIVER KICK
OEM Alarm Disarm SINGLE WIRE SYSTEM THROUGH 2K OMH RESISTOR PANEL *
* Double Pulse On Disarm Will Unlock Doors, Arm Will Lock Doors
Remote Start
Tach Signal
Ignition #2 PINK/GREEN ECM
Ignition #3 PINK / YELLOW TRANS/CHECK ENGIN LIGHT(SMALL ONE)
Accessory PINK / YELLOW RADIO (LARGER ONE)
Neutral Safety BLACK/ WHITE (-) IGNITION SWITCH HARNESS
Brake Light WHITE/ TAN (+) AT SWITCH ABOVE PEDAL
Reverse Light VIOLET/BLACK (+) DRIVER KICK PANEL
Rear Window Defrost
* Ignition #4 BLUE (+) Blower Motor (Large Wire)
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
snguyen
Silver - Posts: 281
Posted: September 24, 2004 at 6:20 PM / IP Logged
Wire/FunctionColourLocation/DescriptionPolarityPic/Graphic
PASSIVE ANTI-THEFT
YES TRANSPONDER SEE NOTES
  2004 dodge ram 3500 diesal -- posted image.
12 VOLTS
Red (2 wires) Ignition harness +
IGNITION
Pink/white Ignition harness +
IGNITION 2
Pink/green Ignition harness +
ACCESSORY
Blue (large gauge) Ignition harness +
ACCESSORY 2
Pink / YELLOW*
Ignition harness +
STARTER
Yellow Ignition harness +
TACH
SEE NOTES*
FUEL INJECTOR
Opposite from Dk.GREEN/ orange At any injector on engine AC
LOCK
Violet/blue**
At harness to rear in driver's kickpanel -
  2004 dodge ram 3500 diesal -- posted image.   2004 dodge ram 3500 diesal -- posted image.   2004 dodge ram 3500 diesal -- posted image.
UNLOCK
Violet/blue**
DOORPIN
SEE NOTES***
FACTORY ARM
Arms with lock
FACTORY DISARM
Disarms with unlock
BRAKESWITCH
WHITE/ tan At switch above brake pedal +
PARKLIGHTS
WHITE/ lt.green****
At light switch harness -
? Vehicle notes
PLEASE NOTE: This vehicle is equipped with TRANSPONDER chips in the ignition keys. This will need to be bypassed for Remote Starter installation. A keyless bypass module may be available, contact your distributor to find out. If one of these modules is not available to you, see the appropriate security diagram for bypass instructions.
* On the 5.2L and 5.9L engines, the Tach wire can be found at the coil on the engine near the distributor. Program you cylinder setting according to the number of cylinders. On the 8.0L V10 engine there are 2 coils packs on the right side of the engine. Use the BLACK/ GRAY at the 6-pack for a 2 cylinder reference.
** One wire system. Use a ground pulse through a 470-ohm resistor to disarm factory security (a second pulse will unlock the doors. A ground pulse through a 2-kohm resistor will arm security and lock the doors. See the door lock diagram for details.
*** Violet (driver's door) & Violet/white (rear left door) both found in a harness on the left side of the brake pedal. Violet/white (pass. Door) & Violet / YELLOW (rear right door) both found in passenger kick panel.
**** Ground this wire through a 330-Ohm resistor to activate parking lights.
Sunday, April 12, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
