Definition of Siren's Long Chirp
zapp
Member - Posts: 7
Posted: September 24, 2004 at 2:34 PM / IP Logged
I have a DEI revenger siren. I think when it emits a "long chirp" it sounds like the thing is going off. It's not the arm/disarm chirp. It seems like when the siren gets a short pulse it chirps, and when it gets a longer pulse, it goes into full alarm. Is that how it works? So there is no "long chirp?" Just full alarm?
I can't seem to find any info on this siren. There's nothing in the owners manual on how to fudge with the siren chirp volume or remove tones. Is there a manual around?
Thanks!
Teken
Gold - Posts: 1,492
Posted: September 24, 2004 at 4:17 PM / IP Logged
Are you sure you are not mistaking the zone fault / bypass sound?
Regards
EVIL Teken . . .
zapp
Member - Posts: 7
Posted: September 24, 2004 at 4:36 PM / IP Logged
Well, that's what I think I'm hearing. I think I'm hearing the bypass sound as a snippet of a full alarm sound. But not the arm/disarm chirp that I'm used to.
Bascially, if I do a zone-bypass arm, (hit arm mutiple times in under 5seconds) I'll get a number of response chirps equal to the # of times I pressed, and then a brief alarm wail...
I think that's supposed to be the "long chirp" described i the manual.
Teken
Gold - Posts: 1,492
Posted: September 24, 2004 at 5:00 PM / IP Logged
First thing I would do is confirm all your default settings and compare them to the manual as it states.
Then, I would enquire the alarm system to see if there are any defective / open zones which are being bypassed.
The system will alert you with LED blinks as well. Watch and listen upon disarm again.
Let us know.
Regards
EVIL Teken . . .
Teken
Gold - Posts: 1,492
Posted: September 24, 2004 at 7:58 PM / IP Logged
Doing what you have discribed simply bypass's the zone{s) in question.
Regards
EVIL Teken . . .
Monday, December 22, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
