parking light flash not working
heathv
Posted: September 24, 2004 at 7:36 PM / IP Logged
I have an Ungo K-10 installed on a 1999 honda accord.  Just in the past couple of days, the parking light flash stopped working.  Doors still lock / unlock with remote control, but parking lights no longer flash.  Please point me in the right direction as to how I might fix this (i.e. what wire to check, fuse, etc). Thanks.
Teken
Gold - Posts: 1,492
Posted: September 24, 2004 at 8:08 PM / IP Logged
Honda
Accord
1998-2002
Remote Starter Wiring Colors and Notes
Function
   Vehicle Color
Location
Start:
   BLACK/ WHITE
IGNITION SWITCH HARNESS **
Ignition #1:
   BLACK / YELLOW
Ignition #2:
   YELLOW
Ignition #3:
Accessory:
   WHITE/ BLACK
Brake Light:
   WHITE/ BLACK
AT SWITCH ABOVE BRAKE PEDAL
Tach Signal:
   BLUE
AT COIL MODULE
Parking Lights:
   RED / BLACK
AT FUSE BLOCK ON DRIVER'S SIDE
<-- Check the fuse in the alarm system as well.
Headlights:
OEM Alarm Disarm:
   BLUE
INSIDE OF DRIVER'S DOOR
OEM Alarm Arm:
   BLUE/WHITE
Diesel Glow Plug:
Clutch Bypass Wire:
Notes:
   * This vehicle is equipped with a transponder immobilizer system; See Installation Note #144 - Bypassing Transponder Theft Systems.
Honda
Accord
1998-2002
Alarm and Keyless Entry Wiring Colors and Notes
Function
   Vehicle Color
Location
Constant +12 Volts:
   WHITE
Starter Kill:
   BLACK/ WHITE
Ignition +12 Volts:
   BLACK / YELLOW
Dome Lights/Superv:
   BLACK/ WHITE (-)
4 PIN GREEN CONN. IN PASS FUSE BOX
OEM Horn:
   BLUE/GREEN (-)
IN STEERING COLUMN HARNESS
Power Lock:
   BLACK/ BLUE (-)
PASSENGER SIDE FUSE BOX**
Power Unlock:
   ORANGE (-)
Trunk Release:
   WHT/RED+
# PIN GRAY CONN. ABOVE DRIVER'S KICK
Alarm Input Wire:
   BLACK/ WHITE (-)
Notes:
** See Note#201 Negative Trigger Door Locks
Platinum - Posts: 12,488
Posted: September 24, 2004 at 8:29 PM / IP Logged
Check to see that the inline fuse on the unit is not burned out. If the parking lights still work then it is definitely something to do witht he inline fuse or the internal relay.
heathv
Posted: September 25, 2004 at 9:12 AM / IP Logged
Well.  The parking lights still work when turned on manually inside the car, but they do not flash when remotely locking / unlocking the car.  I've checked all of the fuses connected to the remote entry system and they are all fine.  I'm not sure how to check the relays's though?  Any suggestions?? Thanks
Posted: September 25, 2004 at 9:33 AM / IP Logged
Internal relays are usually replaced by replacing the unit or bringing it back to the manufacturer for them to desolder them out of the board. If is is the relay, when you lock and unlock the car, the relay for the lights will not click if it is damaged.
kgerry
Platinum - Posts: 3,455
Posted: September 25, 2004 at 10:25 AM / IP Logged
very rare a relay fails... but the parking light circuit from the RS unit does have a separate fuse... without wanting to beat a dead horse... i would suggest you triple check the fuses at the RS unit looking specifically at the one on the parking light wire as Jeff suggested.....
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
mo12v
Posted: September 25, 2004 at 10:30 AM / IP Logged
Have U Unhooked Parking lite wire from RS and Checked voltage on this wire?
Doesn't your UNGO have a source wire for - or + Parking lites?
MO
heathv
Posted: September 25, 2004 at 2:23 PM / IP Logged
I'm trying to locate which wire coming out of the remote entry box is for the parking lights.  Anyone have a clue about this?   The only intallation manual I'm able to find online is for a different ungo system (MS2007), and I'm not sure if they are the same.  Thanks for all your help thus far.
Posted: September 25, 2004 at 2:52 PM / IP Logged
I thought you mentioned that you checked all of the fuses parking light flash not working -- posted image.? Check the RED / YELLOW wire on the unit. This should have a fuse on the wire.
Saturday, February 21, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
