engine noise 99 escalade
Remi_357
Posted: September 26, 2004 at 1:41 PM / IP Logged
ok here is my setup......
pioneer avh-p7500dvd up front
stock bose speakers, factory wiring disconnected, new wire ran
sony xpload 4-channel
2 mtx 81000d
4 s12l7's
power wire drivers side 0 gauge
all other wires passenger side
ground loop isolaters on ALL rca's from the head unit
all amps on the same ground, on a seat belt bolt
the engine noise is VERY loud and annoying, what is causing this? If i disconnect all rca's from the headunit, and hook the up one at a time with a isolater there is no noise more than one rca, noise is back. Without the isolators the noise is always there no matter what, please help
forbidden
Platinum - Posts: 5,354
Posted: September 26, 2004 at 4:21 PM / IP Logged
Really poor ground location. The bolt hole you are using is actually one of the worst possible grounding areas. This is because the nut on the backside of the sheetmetal is basically tack welded on. Either run a new ground wire direct to the battery or first scrape the paint clean in a new area and make your ground connection at this new point. I hope that you have already upgraded the ground wires from the battery to chassis and battery to alternator as well. If not, these need to be done pronto.
Have you tried muting plugs yet?
What are muting plugs Rob?
Muting plugs are designed to dead short the input section of the amplifier. Take some crappy old welfare rca cables and snip the wire about 3" from the end. Connect the center conductor to the outer conductor (thus creating a short). Make more of these as you'll need them. Plug them into the rca input of the amplifier. Do you still have noise. Yes = problem with amplifier and wiring, No = problem coming from head unit (in most cases but not all).
I'm still betting on the ground as being bad, get it changed first and post up the results.
