volvo 850 95
marcopolo
Member - Posts: 7
Posted: September 29, 2004 at 5:32 PM / IP Logged
I install a viper 791xv but the remote starter only works when i the key is in the on position i had trouble finding the ignition wire i think this is my mistake i connect the pink wire from the satellite to a wire that shows 12 whwn the ignition is on but during crank the voltage drops all the way to zero and icant find a similar wire in the column harness that shows the correct voltage during craking
kgerry
Platinum - Posts: 3,455
Posted: September 29, 2004 at 5:49 PM / IP Logged
ign is blue/red in the ign harness
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
Thursday, February 19, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
