tauras auto door locks
mike23662002
Posted: September 30, 2004 at 6:49 PM / IP Logged
2003 ford tauras,doors lock them selves after the car is in gear and the gas pedel is hit.This about to drive me nuts.How do you stop it? thanks mike
mike23662002
slow_hoe2001
Member - Posts: 42
Posted: September 30, 2004 at 8:00 PM / IP Logged
read the owners manual bub.
swamprat323
Gold - Posts: 1,335
Posted: October 01, 2004 at 6:07 PM / IP Logged
Is it the gas pedal or when you move 3-5 mph. Im sure you can disconect that soem were, may have to call the dealer.
Never seen one on the gas pedal, but then again have not dealt with every car out there.
slow_hoe2001
Member - Posts: 42
Posted: October 02, 2004 at 5:10 PM / IP Logged
aiight mike i got this imfo from a buddy that has a 01 taurus so maybe it will help you out.  turn the ignition key to RUN then press the door UNLOCK button 3 times. turn the ignition key to OFF then press the door UNLOCK button 3 times.  turn the key to RUN and within 5 seconds press the UNLOCK button 1 time. you should recieve a horn chirp if you have completed it correctly. let me know if it worked.
mike23662002
Posted: October 03, 2004 at 7:01 PM / IP Logged
CREDIT FOR THE ANSWER TO MY PROBLEM GOES TO  slow_hoe2001 "turn the ignition key to RUN then press the door UNLOCK button 3 times. turn the ignition key to OFF then press the door UNLOCK button 3 times.  turn the key to RUN and within 5 seconds press the UNLOCK button 1 time. you should recieve a horn chirp if you have completed it correctly"
mike23662002
Thursday, May 9, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
