2003 Chevy Impala tach wire
ivanca
Member - Posts: 34
Posted: September 30, 2004 at 9:52 PM / IP Logged
Thanks so much,
Because I am new at this, so I am not really sure which one is the distribotor. It is better that there is a picture.
profuse007 wrote:
assuming its a distributive coil, so look near the distributor. wires leading to the distributor.
mo12v
Posted: September 30, 2004 at 9:54 PM / IP Logged
NO, ..........The Injectors R under Plastic Motor Cover   Just remove oil filler top and pull up on Engine cover.  The Injectors R round with 2 wires going to them.  There R 6 across the top of the engine with the Fuel lines (usually chrome) attached to them
MO
profuse007
Gold - Posts: 2,015
Posted: September 30, 2004 at 11:29 PM / IP Logged
i hope he knows how the fuel line would look like b4 locating the injectors.
Houston,TX
ivanca
Member - Posts: 34
Posted: October 01, 2004 at 12:13 AM / IP Logged
You are right. I dont know that......
ivanca
Member - Posts: 34
Posted: October 02, 2004 at 11:04 PM / IP Logged
Here is a picture I get it on internet. It looks like my friend's car. Could you tell me which one is the injector?
2003 Chevy Impala tach wire - Page 2 -- posted image.
ivanca
Member - Posts: 34
Posted: October 02, 2004 at 11:07 PM / IP Logged
Maybe this one looks much better as my feriend's car. It is 2000 Impala.
NowYaKnow
Gold - Posts: 1,217
Posted: October 03, 2004 at 12:59 AM / IP Logged
If you look in my picture you'll see the circle near the back of the engine. All the spark plug wires should be going to this module, and there should be a wire harness coming off of this module. You want the white wire at this module. Feel free to unplug the wire harness (with the car off of course) if it makes it easier to tap into the wire.
Also it looks like that blue wire I circled isn't fused.. If so, put a fuse on that before it causes any trouble.
ivanca
Member - Posts: 34
Posted: October 03, 2004 at 1:04 AM / IP Logged
Thanks so much. I stay on line for your guy's answers.
My friend told me that tach wire should not work well because tach signal is not strong on GM car. Is it right?
And where is the injectors? Coudl you circle it out?
ivanca
Member - Posts: 34
Posted: October 03, 2004 at 2:10 PM / IP Logged
Thanks your guys!!
I finish it and it work well now. In Impala 2003, It is the TAN/BLACK not the WHITE wire.I tried White wire but didn't work.  Only the TAN/BALCK wire works well. See the picture below:
ivanca
Member - Posts: 34
Posted: October 03, 2004 at 2:27 PM / IP Logged
I installed 3 remtoe start alarm. But I dont know what are the differents between the following tach detection ways.
I think the most common way is circle 5 rounds on Ignition coil :
Another way is directly connect to the wire who gererate volts when engine starting:
I dont understand the first way. How can it gererate volts when engine start? How much votls can it generate when engine is starting.
